yamabond grip glue on symtec heaters? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-28-2008, 04:59 PM Thread Starter
Directions call for a 2 part epoxy but I am out and already bought yamabond grip glue. Any problems?
becoyote is offline
post #2 of 13 Old 04-28-2008, 05:29 PM
not sure i follow the question.
you've bought symtec grip heaters, and symtec recommends a specific grip glue, which you don't have. you want to know if yamabond grip glue will work? didn't the symtec kit come with adhesive?
if not, i'd be tempted to order the symtec recommended stuff. i could easily imagine regular glue losing its grip once you crank up the heat.
but i'm just guessing; i've no firsthand experience with symtec/regular grip glue.
TouringDude is offline
post #3 of 13 Old 04-28-2008, 06:28 PM Thread Starter
Symtec comes with adhesive to put the heaters on to the bars. I am looking at adhesive to bond the grips to the heaters.
I already have yamaha grip glue and am thinking the recommended epoxy would be permanent forcing me to destroy the heaters if I want to change grips or bars etc..
I am basically asking if anyone thinks the yamabond would take the heat.
becoyote is offline
post #4 of 13 Old 04-28-2008, 06:38 PM
What Kinda Bike Is That?
Black Lab's Avatar
The Symtec heaters don't need a glue to apply them. They have a self stick adhesive on the handlebar side of the element. Peel the paper off and apply the heating element around the bar tube like a bandaid.
I removed my OEM grips. I shaved off the ridges of the throttle tube with a razor blade to make it easier to install new grips. I installed Progrip, Gel-Touch grips. I purchased the recommended glue with the kit, (Scot's ski pole grip glue.....), but I DID NOT use it. My grips are tight and don't move or slip. Even when under high heat. Which is very rare. You will mostly use a "low" setting. You will love this addition.
B.
Black Lab is offline
post #5 of 13 Old 04-28-2008, 06:54 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
Are you re-installing the stock grips over the Symtecs?
I didn't use any glue putting my stockers back on. I lubricated the inside of the grips with rubbing alcohol and slipped them back on. No problems...they haven't budged.
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #6 of 13 Old 04-28-2008, 09:40 PM
silverstrom's Avatar
I asked this same question recently and was told hairspray works very well. It helps the grips slide on and then gets tacky to keep them there.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #7 of 13 Old 04-28-2008, 10:41 PM Thread Starter
Went ahead and used the grip glue. Hope it's okay with the heat.
becoyote is offline
post #8 of 13 Old 04-29-2008, 08:31 AM
morm914's Avatar
I used Honda's grip glue to put my stock grips back on over my symtecs. It is probably the same as the Yamaha stuff. I've used it on two different bikes now. It holds fine. No need for the epoxy.
2006 DL650
1972 XS650 Hardtail
1995 250 Ninja ([I]Wifes bike[/I])
morm914 is offline
post #9 of 13 Old 04-29-2008, 04:28 PM
I used hairspray, worked great.
2007 DL650 (Molly)
denysp is offline
post #10 of 13 Old 04-30-2008, 12:29 AM
1+ for the hair spray. Cheap, easy, no mess, and works great.
leftfield123 is offline
