Rotella- just came from Walmart... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 04-26-2008, 11:15 PM Thread Starter
stevet's Avatar
So in a last ditch effort to get some of the last CI-4 Plus generation Shell Rotella T 5w/40 synthetic, I went into Walmart today thinking I was probably too late. Didn't see the gallon jugs, but there were a few quarts left. Then I looked at the lower shelf and noticed it was there in gallons, in a new look. Darker blue bottle with new labeling.
I turned it around to see the specs, and it was still CI-4 Plus, just like we've been using for the past handful of years, not the newest generation CJ-4 like the Shell 15w/40 Triple Protection non-synthetic. I grabbed the last 3 gallon jugs they had, and 3 quart bottles, too.
My guess is- fresh looking bottle waiting for the CJ-4 5w/40 to get pumped into it sometime soon. Reading this link, I don't think I'll be hanging with Rotella after the change to CJ-4 5w/40.
http://www.turbodieselregister.com/TDR57_Oil.pdf
Rotella 5w/40 CI-4 Plus, one of the best in the test. Rotella 15w/40 CJ-4, rated down near the bottom of the results chart.
Get it while you can.
Steve.
Twin Cities, MN, USA
-Me, Steve T.
stevet is offline
post #2 of 15 Old 04-27-2008, 11:14 AM
I remember picking up the new jug for my last bike before I got the strom, but I didn't know about the change to the new specification. I guess I got the old oil in the new jug anyway.
Is there going to be a problem with the new specification to where it shouldn't be used?
Also, after my first 600 mile service next week I was going to dump the shops "oil of the day" and start on Rotella dino 15w-40 until its time to switch to Rotella syn. Is there a problem with the dino Rotella??
JBStrom is offline
post #3 of 15 Old 04-27-2008, 02:05 PM
prothos's Avatar
I just put the dino in mine 2 days ago for my 600 mile change. i will swap to syn on the 3000 mile change also. plus the only place i can find around me that sells the shell is walmart and they did not have the syn even in quarts.
Flat Black Club Member # 29
2008 Suzuki DL 650 V-Strom
prothos is offline
post #4 of 15 Old 04-27-2008, 04:20 PM Thread Starter
stevet's Avatar
It's not exciting reading, and it is aimed at diesel engines, but read that link above for info on the new CJ-4 specification for the commercial grade oils. In a nut shell, the CI-4 Plus oil was the better oil of the two, the CJ-4 has additives that are bowing to the changes in the new low-sulfur diesel fuels and motor oils.
Use that chart with caution, though. Not all of those oils should be used in an engine such as a motorcycle. Gotta read that text carefully to judge it for yourself. Rotella T Syn. 5w/40 will soon be switching to the CJ-4 spec. I found that on another board, someone talked to a Shell rep and he confirmed the Rotella T syn 5/40 will be switching for the new low-sulfur req's, which meet the CJ-4 standard. Look at the donut on the back of the jug for the "C" grades.
I've got enough CI-4 Plus Rotella stocked for 4 oil changes.
Steve.
-Me, Steve T.
stevet is offline
post #5 of 15 Old 04-27-2008, 04:21 PM Thread Starter
stevet's Avatar
You can always hit a truck stop on the interstate, more sold at these places than at Walmarts, used in heavy trucks.
Steve.
-Me, Steve T.
stevet is offline
post #6 of 15 Old 04-27-2008, 04:22 PM
Got a jug of the Rotella T 15/40 Dino here and it claims to meet API Service CJ-4, CI4 Plus etc. I know you're talking synthetic, but if it meets both specs, what would be the disadvantage?
Ragnagwar is offline
post #7 of 15 Old 04-27-2008, 04:45 PM
Chimone's Avatar
thanks for the heads up
2008 VStrom DL1000
2008 VStrom DL650 ABS #09 -Gone but not Forgotten-
Chimone is offline
post #8 of 15 Old 04-27-2008, 05:31 PM
Sulfer is an important product for gear protection. Obviously something an auto/ truck etc.. engine does not have like a motorcycle, so does not need the same percentage. EPA is mandating the lower sulfer in part to help prevent catalytic converter plugging. Removing the sulfer, wear will increase and many oil co. don't have an additive to replace it. Sometimes what mother nature makes can't be reproduced to accomplish the same effects.
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #9 of 15 Old 04-27-2008, 09:05 PM
Byronw's Avatar
oh no, I ran the walmart Rotella syn 5w/40 for 53,000 miles on my old LC, my wife's Marauder, and was planning on using it in our new stroms... now what?
Byronw is offline
post #10 of 15 Old 04-27-2008, 11:05 PM Thread Starter
stevet's Avatar
Check that link I posted, within it provides an anonymous additive chart with sample identification numbers. Then find the actual product against the ID number in another chart. Find oils that are similar in makeup.
I'm no oil scientist, so I'd advise being careful with how you use that information. More is not always better, especially when an oil is designed for one purpose (commercial/diesel use) and being used in a different arena (motorcycles with wet clutches).
It's and engine, right? Yeah, but it is routinely spinning 2-4 times faster than a typical car engine and at higher power output per cc of displacement. In my mind, the inside of a motorcycle engine is a much more severe environment than inside a car engine. In my mind a motorcycle needs an oil that meets a higher level of performance and protection than a typical automobile engine would need.
My car engine spins at 2000 rpm at about 70mph. My bike is doing the same speed but at 5000-7000 rpm (depending on the gear). And the oil is getting thrashed inside the transmission, too. Not an issue in the car.
All else fails, bite the bullet and put in SG rated motorcycle oil. $$$.
Steve.
-Me, Steve T.
stevet is offline
