How do I pull a headlight connector? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-26-2008, 10:38 PM Thread Starter
Corkus's Avatar
I have a ride tomorrow morning and I'll need every watt I can come up with. So I want to pull a headlight connector and spend the 55W on heated jackets.
I flipped the little cover off of the back of the headlight connector. I can see the two wires and their metal tabs. But I can't figure out how they come out of there. I don't want to pull in the wrong direction.
So, how do those connectors come out of there? Do they slide up or down, come straight back or snap out somehow?
Thanks.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #2 of 4 Old 04-26-2008, 10:46 PM
You just wiggle and pull the connector off. They pull straight out. In the following picture, the socket is the same as what you are pulling out and the coupler is pronged just like the headlight bulb. This is for an example of the connections only. The stock bike does not have relays or the other wiring.
post #3 of 4 Old 04-26-2008, 11:10 PM Thread Starter
Corkus's Avatar
Thanks Pat, I was going about it all wrong. I was going to try and pull the wires out of the socket. Now I'll try and pull the whole socket.
I didn't need to flip that little door up on the back of the connector either.
This is very helpful.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #4 of 4 Old 04-26-2008, 11:14 PM Thread Starter
Corkus's Avatar
Done. How fast was that?
4 minutes, reading your post until this post.
Good time. Thanks again.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
