Rotate headlight/turn signal switches up? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-23-2008, 02:00 AM Thread Starter
Question Rotate headlight/turn signal switches up?
Had my DL650K7 for 2 weeks now and have a little over 1k miles on it. Adjusted my levers tonight to account for my seat and riding position, but one thing I wanted to rotate also is the housing holding the headlight/turn signal buttons. I saw two phillips head screws on the bottom side of the housing; loosened them and tried to rotate the housing but it wouldn't move. Instead of forcing it, I figured I shoud ask first if there is something I overlooked or some other trick. I'd like to rotate it up about a 1/2 "
Thx
Lock is offline
post #2 of 4 Old 04-23-2008, 05:29 AM
No longer riding.
handyhiker's Avatar
There is a locating pin that fits in a hole in the handle bars. Some folks have used a drumel and ground the pin off. You would have to take both screws out and seperate the housing. (not that tuff)
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #3 of 4 Old 04-25-2008, 01:56 AM
Clever Title
Be careful if you do this. The housing might be a bit loose on the bars, allowing the unit to rotate. This happened to me when I replaced my handlebars- now my kill switch/starter button housing rotates around the handlebar. I plan to remedy this by shimming it with electrical tape.
Guess I should have been wearing pants...
'86 Suzuki GS450L (redneck-farkled)
'79 Yamaha XS1100 (project bike)
'06 Suzuki DL650 (SW-MOTECH: centerstand, bellypan, crashguards) (3M reflective striping) (Powermadd handguards) (Nelson-Rigg saddlebags and tankbag)
iron_llama is offline
post #4 of 4 Old 04-25-2008, 06:20 AM
quema's Avatar
Another option that really isn't that expensive is to get a set of Moose Racing dirt bike bars, the CR high are nice, they have less pull back than stock, which many people mention helps their wrists. The ATV high are much higher if you are looking for some rise.
These bars don't come with a locating hole in them. Use a drill and make the location where ever you choose.
It took me 30 minutes to switch them over the first time and 20 the second time.
The bars are less than $20. I ended up with the ATV's after trying the CR's and risers and wanting more rise.
And Hawaii!
quema is offline
