Need to shorten sidestand after 3/4" lowering work - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 22 Old 04-22-2008, 09:02 PM Thread Starter
stevet's Avatar
Hi All,
I recently installed 3/4" lowering links out back, and dropped the front end the same 3/4". Working great, feet now flat on the ground and a bit easier to mount and dismount.
But the side stand is holding the bike up too high. There is lean, but I can literally tip the bike over on its right side by simply pressing down on the right saddlebag, or getting on the bike with a bit too much vigor- almost lost it one day just getting on! (Haven't let it fall, but it takes very little effort to get it to go over.) I've got Pelican 1440's out in the back, total system is estimated to be putting another 55 pounds onto the rear end. Just that weight compresses the suspension a little bit, which compounds the bike wanting to lean back over to the right with such little effort as the side stand stands the bike up farther as the suspension is compressed. (Would adjusting the rear shock to firm it up help me here? What would I be adjusting, and where- knob or shock body?)
I need to shorten the side stand. I'm going to search for a second hand side stand and modify it. I want to keep the stocker in stock shape, just in case...
Now, outside of simple arithmetic, I can't do any advanced math. At first blush, I'd want to shorten the side stand 3/4" just like I did for the suspension, but something in my brain is telling me 3/4" off the side stand would be too much.
I need a math brain out there- if you were shortening a side stand, how much overall length decrease would you shoot for to obtain approximately the original lean as was delivered to me by the factory?
Read message 7 of this thread- he went 3/4" shorter. Thoughts?
https://www.stromtrooper.com/forums/s...ight=sidestand
Thanks in advance!
Steve.
Twin Cities, MN, USA
-Me, Steve T.
stevet is offline
post #2 of 22 Old 04-22-2008, 09:10 PM
janiceclanfield's Avatar
Originally Posted by stevet View Post
Hi All,
Thanks in advance!
How about putting 3/4'' board under both tires and trying out the stand to see if you get the lean you want? Dunno if the angle thing would work out exactly right, but I think it'd go a long way in getting the info you need.
janiceclanfield is offline
post #3 of 22 Old 04-22-2008, 10:28 PM Thread Starter
stevet's Avatar
Freakin' brilliant!!! See, guys, where would we be without the sharp mind of a good woman?
I will do this tomorrow evening, Janice, and report back what I discover. I'll mess around with a few different boards of different thicknesses to see what works out.
Steve.
-Me, Steve T.
stevet is offline
post #4 of 22 Old 04-22-2008, 10:33 PM Thread Starter
stevet's Avatar
Originally Posted by rjwinz View Post
This may not seem like a good deal to you but I've got a stock stand that has lowered itself through use. I bet it would work just right on yours, if you want to trade. I may not make it to the tech day on the Strom though since the right fork has puked all of its oil out and I need to get it in the shop for seals. The sonic springs just arrived and I should have a DL1000 shock with a new Hyperpro spring in a week or so. I may ride up on the DR.
Bob W.
Hi Bob,
Uh, sounds like you've got a well used stand strapped to that bike of yours. I don't think I'd want to swap for my nearly new one (I want to keep the current stand for future use or a new owner that may want to raise the bike in the future). Wonder how much a new one costs? I'll search around for a used one.
Anyone have one laying on a shelf that is no longer in use?
Hope to see you Saturday!
Steve.
-Me, Steve T.
stevet is offline
post #5 of 22 Old 04-22-2008, 10:52 PM
Easy fix. Just grind down the stop to allow the side stand to swing forward more. Not much is needed and it will probably still be very serviceable with the stock height.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 22 Old 04-22-2008, 10:54 PM
MightyShep
I dunno, maybe buy a shorter bike? LOL!
post #7 of 22 Old 04-22-2008, 11:10 PM
LarryB's Avatar
Or grind down the spot on the stand where it contacts the stop. Then if you ever put the bike back up to stock height (to maybe sell it), all you need to do is replace the stand and everything is back to normal.
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
post #8 of 22 Old 04-23-2008, 12:48 AM
nvr2old's Avatar
Steve, Ron Ayers lists it for $74.22. Kinda spendy
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #9 of 22 Old 04-23-2008, 12:52 AM
Steve, when I had my bike lowered one inch I ground the stops of my kickstand to let it go forward further and allow additional lean. I have removed the lowering links and traded them for something else.
Want to change kick stands on Saturday?
JayR is offline
post #10 of 22 Old 04-23-2008, 12:59 AM
Steve, for some reason it won't let me edit my previous post.
On Saturday you will see that the extra lean when you raise it back up is not that severe. I am willing to trade if you want. My bike only has 10,150 miles bought Dec. 06.
JayR is offline
