Anyone tighten their throttle cable? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 04-14-2008, 02:43 PM Thread Starter
I've got a little jerkiness in the throttle from idle. I tightened the chain and the jerkiness is still there. I read somewhere else that slack in the throttle cable connection to the throttle bodies will cause a jerky throttle response. Anyone else have to deal with this? Difficult to fix?
Toad Rider is offline
post #2 of 15 Old 04-14-2008, 02:48 PM
Define jerky throttle response. Are you trying to run the engine below 3000rpm?
post #3 of 15 Old 04-14-2008, 04:32 PM Thread Starter
From resting throttle to initial input, no matter now smoothly I turn it.....it jerks.
post #4 of 15 Old 04-14-2008, 05:01 PM
Are you using the clutch? If not, that's your problem. Lower speeds require clutch slippage and more revs. If you are using the clutch, it's the clutch or your use of it that is suspect.
post #5 of 15 Old 04-14-2008, 05:05 PM
jackpiner57's Avatar
It sounds like you need to check your TPS (throttle position sensor) setting. Also, adjust your throttle cables until you have about 1/8" freeplay. Do a throttle body synchronization too (you can make your own manometer). I would do all 3 of these. All of these are easy to do if you have some mechanical ability. Do a search on this forum for threads that deal with these issues and have instructions.
If you don't have a service manual, I can e-mail you one. A small piece of wire can put your bike in "dealer mode" to check the TPS setting on your LCD display. Let me know if you need help on this.
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #6 of 15 Old 04-15-2008, 01:53 PM
Kawidad's Avatar
What's you idle speed set at? If it's too low, that'll do it.
Kawidad
2007 DL1000K7
Kawidad is offline
post #7 of 15 Old 07-22-2008, 06:22 PM
Not meaning to resurrect old threads (It's not *that* old!)... but I'm experiencing something that I would describe the same way...
I've noticed it in 2nd gear quite a bit... When I'm cruising at about 50 kph, bike at 4000 to 5000 rpm, if I let off the throttle all the way, it feels like an on/off switch... gently turn it back on, and nothing, until WHAM it feels like I get jerked forward quite a bit... As noted above, this is at speed, and decent RPM's... It feels like the throttle itself is going from completely closed to 10% open in a non-smooth manner... everything after 10% feels analog in nature, nice and smooth.
I've adjusted the throttle cables and done the throttle body sync... Is there anything else that might make this feel better (On an 08 Vee)
R
Rebes is offline
post #8 of 15 Old 07-22-2008, 09:08 PM
In manual you will find that there should be between 2 and 4 mm of play before engagement so throttle won't open inadvertantly when turning tight corners.
It is a bit of a pain as it does feel like an on off switch.
I try to guage with my wrist just as the I return to idle and not let her close completely....not to successful.
Unless you adjust all the end play out which you are not supposed to, I believe you will have to live with it.
Makes it a bit hard for gracefull throttle applications sometimes don't it.
Toto is offline
post #9 of 15 Old 07-22-2008, 09:58 PM
throttle adjustment
just did mine and it did clean up some of the "hard to be smooth" stuff in the wee, like riding slowly across a parking lot ..there was not much adjustment left, but it has made a diff. Simple to do
terrysos is offline
post #10 of 15 Old 07-23-2008, 01:36 AM
I ended up adjusting my throttle cable as well as adjusting my riding habits. I took out the slack on my throttle cable by feel; I'd set it, then swing the bars back and forth to check whether there was any different in play, then adjust from there. Nevermind the manual - do what feels right.
In terms of my riding habits, I slowly roll off the throttle now instead of just "snapping it down". I still end up in the same place (rolled fully up) but I do it in five seconds instead of one. My Wee is nothing like the Shadow 600 that preceded it: it's a lot better. It will require more from you as a rider but it'll make you a better rider at the same time.
[I]Make the most of yourself, for that is all there is of you
Don't get caught on the wrong side of the second hand
The grass may be [COLOR="Green"]greener [/COLOR]on the other side, but it still must be mowed[/I]
[SIZE="1"]Farkles: SW-Motech center stand, VStroma crash bars and skid plate, Genmar up-and-backs, Givi rear rack, JCW cases, poor man's GPS. On order: Murph's lowering links[/SIZE]
ampersat is offline
