Givi Engine Guard Installation Problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 04-13-2008, 12:42 AM Thread Starter
I am having a problem removing the engine bolts to install my Givi Engine Guard. Is there an easy way to remove them.
gordonc is offline
post #2 of 14 Old 04-13-2008, 12:51 AM
Byronw's Avatar
I busted two tools getting one of the bolts out of mine, a 6mm hand key and a cheap (harbor freight) 3/8 inch socket. Going to sears for the 6mm socket worked, was really in there though. One thing someone recommended was a whack with a rubber mallet on the socket to "break" it loose. All the bolts on my wife's 650 came out easy, but I was beginning to wonder if I'd get them out of mine.
Byronw is offline
post #3 of 14 Old 04-13-2008, 02:07 AM
klantz's Avatar
Invest
Get yourself an impact wrench... it is a handy dandy tool.
klantz is offline
post #4 of 14 Old 04-13-2008, 02:39 AM
jwt
jwt's Avatar
+1 on the having to go to sears because your inferior tool broke. While installing my givi bars, my wal-mart el cheapo stanley tools took a massive chinese dump on me. The quality of metal that the rachet connects to on the stanley socket is similar to a dehydrated wiffle bat. I had to ride to sears w/ right side only givi bars on, courtesy of chinese quality. Say what you will about sears; they [email protected] times too, but stanley totally blows in comparison. Buyer beware.
"I believe the most damning thing that can be said about muslims is saying you're afraid to say anything."--Penn Jillette
Pointless Profanity Club member #10 ****face.
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
jwt is offline
post #5 of 14 Old 02-04-2009, 08:39 PM
ditto on the chinese crap. use once, maybe, then discard
eddiemurphydyte1 is offline
post #6 of 14 Old 02-04-2009, 10:05 PM
On the rare occasion that a Craftsman hand tool wears or fails, just take it back for a free replacement... for life.
04 DL650, 18k+ miles, lowered, grip heaters, hand guards, touring laminar lip, trunk, soft saddlebags (when needed), aprillia mirrors, frame&swingarm sliders, fork brace, skid plate
re-psycle is offline
post #7 of 14 Old 02-04-2009, 10:20 PM
bigboy292000's Avatar
What you should start worying about is putting the new (Givi) bolts in...
Search around and you will see that many of us had issues with this. My suggestion is to at least clean the holes very well and use a wire brush or something to clean the threads of original Givi bolts as they are powdercoated (yes - including threads).
Very hard to get in there unless you do that! This includes a little flat headed screw that attches a small triangular plate on. A crimp on one of mine failed because of this (I cleaned it with wire brush but apparently not enough).
https://www.stromtrooper.com/showthread.php?t=33561
Take your time, vey easy to cross-thread.
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #8 of 14 Old 02-05-2009, 12:04 AM
Fozzyber's Avatar
This was a niffty tool I got at Sears.
http://www.sears.com/shc/s/p_10153_12605_00941111000P
it is a set of bits and a large holder, you can get a good bit of power behind it.
It is also small enough to be put under the seat.
and strong enough to put a cheater on it.
if all else fails i get out the allen sockets and my 24" breaker bar.
Fozzyber / jerry 09 dl650(Vicki)
Farkles: -200lb meat Popsicle aka: the driver
-Scotts Steering Dampener, OEM Hand Guards, Trackside Heated Grips<= sux, GIVI Engine Guards. GIVI windscreen, ProTaper ATV high bars, Aprilia Tuono Mirrors, EB Fuse block, and horn relay kit. Stebel horn, Givi Side racks, madstad, zuk gel seat, garmin 760,LIN 3 tail light, 15T front gear, E36 & E45 Side cases, E55 top box
http://www.cypressgraphics.com/motorcycle.html
Fozzyber is offline
post #9 of 14 Old 02-05-2009, 12:23 AM
TravellingStrom's Avatar
Send a message via Skype™ to TravellingStrom
I have installed these on two bikes now and can give the following advice.
I used the Allan key from under the seat, yes the OEM tool. I then used the handle of my trolley jack as extra leverage and applied gentle but firm pressure with NO hammers or sudden jerks. This allowed me to crack the seal of the thread lock used in the factory. I never had any problems with this. As soon as you apply shock or sudden pressure, that is when things break.
Once the bolts were out, I then used a TAP to clean the thread of the old thread lock. This made it easier to install the Givi bolts.
I would not be using anything like hammers and impact wrenches, but that is just my opinion and I have no need of them for this type of job.
Cheers
TS
0utrageousfun likes this.
www.TravellingStrom.com
TravellingStrom is offline
post #10 of 14 Old 02-05-2009, 10:11 AM
weekend_warrior's Avatar
I will be doing this soon as I ordered. I have a Hex head socket set and the 18 breaker bar that should to the trick. Steady and firm pressure all the way. I find that i don't have to break out the impact for much on the motorcycles. I also don't need much more than a 1/4 inch drive wrench.
Thanks for the tips about the cleaning out the threads with a tap and taking off the powder coat on the bolts. I will be doing that. I'm anticipating that things will go easy.
07 V-strom 650 (gray)
06 KTM 450EXC (Plated)
94 DR350 (Old Faithful)
weekend_warrior is offline
