Need advice to lessen windblast on arms/shoulders - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 04-11-2008, 12:55 PM Thread Starter
Any experience with lessening the windblast on arms and shoulders?
My Wee is equipped with the stock windshield, Madstad, and Rick's mirror extenders. I have been searching the forum and it looks like maybe a wider windshield will help the windblast? If so, what windshields or add on (Laminar Touring Lip) seem to deflect the air furthest to the sides and away from the arms/shoulders?
If it helps, I'm 5'6" with a 29" inseam.
Thanks!
2006 650 V-Strom, totally farkled
2006 HD Dyna Super Glide
2004 883 Sportster... now my nephew's
1990 Honda PC 800 (sold and replaced with a Wee)
1974 Honda ST 90 (Sold 30 years ago. My first motorcycle ))
cyclist63 is offline
post #2 of 21 Old 04-11-2008, 01:22 PM
Colin's Avatar
I have a Givi. It is wider and I got it to help deal with exactly what you mention. Not perfect but it sure helps. The Givi is also taller so at 5'6" you may find it too tall. The Madstad should help with that though.
From TwistedThrottle website:"The Givi replacement windscreen measures 22.4 inches (570mm) tall x 18.9 inches (480mm) wide, approximately 7.1 inches (18cm) taller than the original windscreen."
Colin is offline
post #3 of 21 Old 04-11-2008, 03:29 PM
I also have the GIVI on a madstad. For me it is the perfect setup. It is a bit wider than the stocker so it does cut down on the sholder blast.
RShrimp is offline
post #4 of 21 Old 04-11-2008, 04:20 PM
Berserker's Avatar
Uhhh you're on a motorcycle...
there's going to be wind. Or I guess you could try a cage or Goldwing
[U][URL="http://moveyourmoney.info/"]Move Your Money[/URL]
[/U]
Berserker is offline
post #5 of 21 Old 04-11-2008, 04:42 PM Thread Starter
Thanks for the information. I'd rather not look through the windshield. I'll have to check on the "tallness".
Thanks. Sounds like a wider shield than stock and lower than a Givi would help with my problem
I know there is wind. I don't mind some wind, but at 135 lbs, I sometimes need all the help I can get. I don't quite fit an 800 lb Goldwing
post #6 of 21 Old 04-11-2008, 09:41 PM
Faulkner's Avatar
I ride the one on the right when I don't want much wind blowing in me. You'd be surprised at how well balanced they are.
2014 HD Electra Glide Ultra Classic
2008 Suzuki DL650 V-Strom (Flat Black Member #18 )
2007 HD Electra Glide Ultra Classic
2003 Suzuki Volusia
Faulkner is offline
post #7 of 21 Old 04-11-2008, 10:59 PM Thread Starter
Appreciate the comments on a "big" bike, but I am looking for ways to customize the Wee for my style of riding and what I am comfortable with. I have a Sportster as well as the Wee and everytime I walk into the Harley dealership they tell me "You can ride that Road King or Electraglide no problem". Sure, balancing a big bike is no problem in a straight line while moving but moving a 700-850 pound bike in tight spots or trying to muscle it around in the garage IS a problem when you don't weigh alot.
post #8 of 21 Old 04-12-2008, 02:24 AM
Fatstrat's Avatar
Yea, I'd swap the Strom for the tractor too if I was in the mood for a little windless cruising. I have driven a few myself and I agree, those things balance great on four huge tires.
(sorry, couldn't help myself)
:rofl:
Previous bike...
2007 DL650 ABS, grip puppies, factory hand guards, backoff brake light modulator, givi rack with JCW 'side' cases, K&N air filter, swing arm spools...
Shopping for some new wheels now.
Fatstrat is offline
post #9 of 21 Old 04-12-2008, 08:35 AM
stromer's Avatar
try a Windstrom manta they have a curved lip on the edges of the windshield and work great. The only thing is they are a little pricey, but excellent quality.
just give it a little gas, it will be ok !!!
stromer is offline
post #10 of 21 Old 04-12-2008, 09:38 AM
garandman's Avatar
the curved lip is one of the things that creates turbulence.
I have a Givi and a California Scientific tall. I use the Givi as a "summer" windshield. If you're shorter/narrower the Givi will work. Behind the CalSci the world is a quiet place.
garandman is offline
