Sargent vs Corbin - Initial Impressions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 04-11-2008, 12:54 PM Thread Starter
I've been riding with the Corbin Canyon seat since last fall and I'm very satisfied with it from a comfort standpoint. As I've explained in other posts, I'm going on a month-long tour with my 19 year old son in 4 weeks. I'm loaning / donating my current 07 Vee to my son for the trip and buying another Strom for me to ride on the trip. For the new bike I decided to buy a Sargent so we'll be able to swap back and forth for a change on the fanny without the same hotspots, and because Sandhill had them on sale so cheap compared to the Corbin.
The Sargent seat came in today, too. Looks GREAT. Better and sleeker than the Corbin IMO. Mounted easily on the bike and hugs the frame really tight. It did have some small tank on the underneath side that I didn't take the time to check out.
Seems to be very comfortable - equal to the Corbin - but of course judgement on that will have to be suspended pending a lengthy road test.
Biggest difference: The Sargent is much lower and narrower in the front, with a more forward riding position. With the Corbin I cannot plant both feet firmly and usually lean to one side and still on a tip toe. With the Sargent I can plant both feet and even have a slight bend in my knee. Got to be at least 1/2" - possibly over 1". With the Sargent my windscreen is now too high. I will have to move the Madstad bracket down from the middle setting to the low setting and readjust the windscreen.
Will experiment with the Nelson Riggs soft saddlebags tonight.
CarbideDude is offline
post #2 of 19 Old 04-11-2008, 03:19 PM
TheTwins's Avatar
I can't wait for more information. I am about to buy a Sargent, originally was considering the Corbin. I am headed to Alaska in May so I will make the purchase in about a week. Please post more as you go. Thanks.
TheTwins is offline
post #3 of 19 Old 04-12-2008, 01:03 AM
quema's Avatar
I also am interested in hearing more.
I was thinking of a custom seat, but it seems with either of the mayer's brothers you are way better off driving in (which given that I am in Hawaii is impossible). So I have resigned myself to the Corbin or Sargent.
I am tall enough (6') that I don't think I would mind the reach of the corbin, infact, I really don't want to give up any height over stock, as I like my legs streched out as much as possible.
I am pretty certain, unless you give me some advice to the contrary, that I will end up getting the Sargent from Sand Hills. Although there are mixed reviews on preference with sargent/corbin... well, most people only own one and review that their's is the correct choice.
... So after the weekend, maybe you could post a few more thoughts?
Thanks.
And Hawaii!
quema is offline
post #4 of 19 Old 04-12-2008, 07:59 PM
I initially had no problem with the stock seat . That changed at about12000 miles.
I bought a Corbin-nicely built piece, however the front was too wide, @6-1 with a full tank and skinny legs I was a bit uneasy at stops. I got an rma for a nose job, big hassle,ultimately I sold it. I found it cumbersome and I thought not well suited to the bike. Fit was fine.
I bought a Sargent-flimsy by comparison,much lighter and the foam seemed soft.It has performed very well been very comfortable,easy to move around on,very nuetral in most respects(not hard not soft ,similar to the original only better)
The corbin had caused me to adjust handlebars and change reach,its no contest between the two for me.
jamesm is offline
post #5 of 19 Old 04-12-2008, 08:42 PM
jwt
jwt's Avatar
I got a sargent seat from sandhills two weeks ago. I'm 6'2 and 185. Never tried a corbin. 2007 650,btw. The sargent seems to slope forward a bit, but I stay planted in it and don't find myself sliding forward. It seems to me the padding feels close to stock, but the design is a lot better. Less pressure point problems. Wider than stock-that helps. Comfortable seat to me, I'd be whining if I said it hurt me, for true.
"I believe the most damning thing that can be said about muslims is saying you're afraid to say anything."--Penn Jillette
Pointless Profanity Club member #10 ****face.
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
jwt is offline
post #6 of 19 Old 04-14-2008, 05:41 PM Thread Starter
Ok here's an update. I did about 100 miles on Saturday and 60 on Sunday. More to contrast:
If you got a big butt, you should go Corbin for sure. The Corbin seating pocket is much larger.
Incredibly, the bike handles noticably better with the Sargent seat. The lower center of gravity coming from 2 sources: (1) the Sargent has a lower seating position as I mentioned, and (2) since the Corbin is so much heavier than the Sargent, that's a lot of weight on the top portion of the bike.
The Corbin is very hard, but very comfortable. The Sargent is quite a bit softer.
On my ride down to Tuscaloosa, I actually struggled to find the sweet spot on the Sargent where I was totally comfortable. I did not have this problem on the Corbin, and from the minute I started riding with it I was completely comfortable. I found myself constantly fidgeting on the Sargent. On the way back I realized that this was coming from the fact that it was sloping down towards the front quite a bit, and forcing the bulk of my weight to be carried by the narrow bridge - the same narrow bridge that made possible the easy footing. The Corbin's nose is much wider and rounder.
I had been running my height adjustment near the top, and the following day I adjusted it down to the lowest setting. Bingo. The Sargent was suddenly quite comfortable, and for the duration of my ride on Sunday I was not squirming or struggling to find the right seating position. Even with the lower seat height, for some reason I cannot explain, I did not find myself feeling like my legs were squished up more so than normal. They felt the same, even though the Corbin is certainly higher.
I am 6' even with a 33" inseam, and my son is 5'10" with a 28-30" inseam. He gets the Sargent seat for our tour, because he will benefit the most from the lower height. We will have so much highway / freeway time I'm perfectly happy touring on the comfort of the Corbin. When we get back I may steal the Sargent from him from time to time. I am also a daily commuter, and in those conditions the Strom definitely feels more fun to throw around with the lower seat height of the Sargent.
post #7 of 19 Old 04-14-2008, 06:09 PM
Living the Stereotype
Stromin'Nroman's Avatar
Originally Posted by CarbideDude View Post
If you got a big butt, you should go Corbin for sure. The Corbin seating pocket is much larger................................
I did not have this problem on the Corbin, and from the minute I started riding with it I was completely comfortable. .........................
CD,
You see what you're telling us about yourself.
Well, thanks for the comparo, I was considering the Sargent, but I feel the stocker pushes me to far forward, would you say the Sargent does this more than the stock seat?.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #8 of 19 Old 04-14-2008, 07:08 PM Thread Starter
Originally Posted by Stromin'Nroman View Post
CD,
Actually I don't even remember much about the stocker, except that the Sargent is a huge improvement. I think the main thing with the Sargent is just getting the rear height adjustment set to balance it out.
With what I know now, if I had to choose one or the other and hadn't already made my purchases, I would get the Sargent. I really like being down lower, and despite the rumors flying around about me now, my butt is perfectly happy in the smaller seating pocket of the Sargent. The bike just has better manners and is easier to jump on and flit around, with the lower center of gravity. Did I mention the Sargent looks better?
post #9 of 19 Old 04-14-2008, 10:00 PM
Don't wait too long to order the Sargent. Mine took about 3 weeks to receive after placing the order. That was last August. I would think demand might be higher this time of the year.
bradster
bradster is offline
post #10 of 19 Old 04-14-2008, 10:48 PM
I just ordered a Sargent.
I had a Mustang seat on my Harley, and it was quite nice. I see Sargent distributes Mustang seats also.
I like the Russel idea, but not the price or that I have to send in my seat and ride nothing while I wait. I could ride to Lake Shasta and wait, but not for an extra $80.
watcher is offline
