Oil level keeps rising! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 36 Old 04-10-2008, 11:49 PM Thread Starter
Highveelocity's Avatar
I changed my oil and filterfor the first time the day before yesterday. I started it up after adding to the fill line, and then shut it off. I waited a few minutes and then added oil again up to the fill line, eveything is good, right? I drove it to work yesterday, and I checked the oil level again a couple of hours after I got home, it was above the fill line! So I take some oil out, down to the fill line again. The next day, after work, same procedure, high again! WHat gives? All this was checked on the center stand.
'05 Silver Wee, Givi crash bars, Scotts dampener, JC top box, Battlewings, Homemade fork brace, GSXR calipers with homemade brackets. TCI Outback luggage System, Mr. Eds Moto custom seat
http://s288.photobucket.com/albums/l...ty/56%20Chevy/
Life, repression, and the pursuit of tax money
Highveelocity is offline
post #2 of 36 Old 04-11-2008, 12:06 AM
rhithyn's Avatar
From what I've been told, it's better to balance the bike to check the oil... the center stand might keep it at a slight side-ways angle and give you a false reading.
[I][SIZE="2"]Now Wee-strom-less... [/SIZE][/I]
[I][SIZE="1"][COLOR=DarkGreen][FONT=Franklin Gothic Medium]"A car is a means of getting around that can be enjoyed
A motorcycle is a means of enjoyment that can be used to get around"[/FONT][/COLOR][/SIZE][/I]
rhithyn is offline
post #3 of 36 Old 04-11-2008, 12:26 AM Thread Starter
How can I balance the bike without being on it, and still see the glass? The bike looks perfectly straight up and down, and besides, that doesn't explain why it keeps rising. Weird
post #4 of 36 Old 04-11-2008, 12:58 AM
These bikes are light. Stand on the right side (throttle side). Grasp the luggage rack rail and the throttle. Lift the bike up. Squat down holding the luggage rack rail. Oil sight glass is clearly visible. The more you do this, the easier it will be. Be assured... once 'up' the bike is VERY easy to balance with one hand. Takes little to no effort.
HappyWanderer is offline
post #5 of 36 Old 04-11-2008, 01:19 AM
$tromTrooper
MTNAdventureRider's Avatar
If I am correct, the manual calls for 2.9 quarts of oil. I overfill by 0.1 quarts, because I put in 3 full quarts on every change.
I wouldn't experiment with the "fill glass level" on the initial change, thinking that it was accurate. I simply look at the glass, prior to every start-up to make sure she simply has some lube in the case.
I change every 3k miles and so far, have not noticed any lose of oil in that amount of mileage, even with a lot of 75mph riding on the interstate.
Big John
2007 DL650 - Gone but not forgotten
MTNAdventureRider is offline
post #6 of 36 Old 04-11-2008, 05:43 AM
No longer riding.
handyhiker's Avatar
Sounds like you filled it and did not let the oil settel back down before you topped it off. When I had a center stand I always checked my oil this way also. For the record, I also just use 3 Qts. Butif I were you, let the bike sit over night on the center stand. Then drain the oil down to the full mark. All should be good.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #7 of 36 Old 04-11-2008, 05:50 AM
MeefZah's Avatar
As long as you check it with the bike parked in the same spot / direction every time, it wouldn't matter. I use the centerstand. It is scads easier and if there is a slight "angle" it won't be significant enough to matter, and if you duplicate the same angle every time you check you will still get an accurate check and be able to determine oil usage.
Procedure (with a new filter installed as opposed to using the old one): after draining the oil, add oil until it is just below the top of the fill window. There should be the tiniest of "bubbles" at the top of the window. Start the engine, let it run for 3 minutes or so (ignore the oil light that comes on for the first 10 seconds), then shut it off. Go away and get on Stromtrooper for an hour or so. Return to the bike, add oil to 2/3 full in the window (shouldn't have to add much). Done.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is online now
post #8 of 36 Old 04-11-2008, 07:42 AM
BubbaGee's Avatar
Send a message via MSN to BubbaGee
I have had good luck with putting a standard paving brick under the kick stand. It keeps the bike steady and pretty much upright so I can check the oil with concern of it tipping. Of course the bike needs to on level ground to begin with, I do it in my garage. Best of luck. I think the manual says to wait 3 minutes after turning the engine off before checking the level to give the oil time to drain out of the engine. Keep in mind that the 3 minutes is based on a warmed up engine, not cold.
BubbaGee
2006 DL1000 in red.
"What doesn't kill you only makes you stronger."
BubbaGee is offline
post #9 of 36 Old 04-11-2008, 07:50 AM
All advice given has been great, I also do all my maint while on centerstand. When I change the oil/filter I let it drain until I have no drips "at all", then I refill with 2.9 quarts like specified. My level is always spot on and never changes, and I have no visible oil loss between intervals. Always better to be between the fill lines than above, so I would rather fill with a little less then specified, and then add accordingly.
post #10 of 36 Old 04-11-2008, 08:25 AM
K1W1's Avatar
Wrong, wrong, wrong.
Never ever fill a bike by simply adding oil until you get to the fill line. That will cause you to overfill the bike as you have discovered and will cause you to over pressurise your sump and blow gaskets and seals.
Use this as a learning experience and before you do your next oil change buy a measuring device and add the correct MEASURED amount of oil to the engine after you have first ensured that all the old oil has completely drained.
K1W1 is offline
