Luggage Rack Bolts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-09-2008, 07:10 PM Thread Starter
gremlin's Avatar
Luggage Rack Bolts
I just purchased a 2004 DL1000, it came with the Suzuki branded Kappa luggage with top case. The rack appears to be Suzuki issue. The problem is the top case. The guy didn't like it and he removed the two little mounting posts that the luggage slides onto. The big pyramid looking thing is still there, just not the two little bolts. Would buying this piece get me what I needed?
http://www.twistedthrottle.com/trade...view/2079/169/
gremlin is offline
post #2 of 9 Old 04-09-2008, 07:50 PM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
I'd give a qualified "yes", the qualification being that you might need a different size bolt to hold the "mushroom". I can mic it when I get home and let you know, I have Givi Side Racks and the oem top.
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
post #3 of 9 Old 04-09-2008, 07:57 PM
No longer riding.
handyhiker's Avatar
Yes this will work. You can also make your own very cheaply.
2-bolts
2-nuts(nylock)
2-nylon spacer
2-washers
Install a washer on the bolt(I used a phyllips head screw) then the nylon spacer. Stick this through the rack, then install the nut and tighten.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #4 of 9 Old 04-09-2008, 10:20 PM
Jonnylotto's Avatar
The "Kappa" mushrooms are 19.5mm across at the top and taller than the Givi, which are only 15.5mm across the top.
JonnyLotto
DL-650K5
post #5 of 9 Old 04-09-2008, 11:36 PM Thread Starter
gremlin's Avatar
Pulled one of the side bag screws, I'll take it to the hardware store tomorrow and see what I can find.
gremlin is offline
post #6 of 9 Old 04-10-2008, 12:48 AM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
The replacement parts are cheap. I think you can get a replacement kit for all three mounts for around 20 bucks.. good to have a spare under the seat anyway right?
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #7 of 9 Old 04-10-2008, 09:33 AM Thread Starter
gremlin's Avatar
-GW
From the Suzuki Dealer?
gremlin is offline
post #8 of 9 Old 04-10-2008, 12:48 PM
GrayWolf's Avatar
I think I just ordered them online from a reseller.
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
post #9 of 9 Old 04-11-2008, 01:09 AM Thread Starter
gremlin's Avatar
Any details you've got would be awesome, my Suzuki dealer couldn't find anything. I built some at the hardware store, but they don't fit nearly as nicely as the stock ones.
gremlin is offline
