Heated Grip Switch Location - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 04-08-2008, 03:06 PM Thread Starter
Allan's Avatar
To everyone who has third party heated grips. Where did you mount your switch? Photos would be great!
"Aqaba is over there, its only a matter of going." -Lawrence
2007 V-Strom 650
Allan is offline
post #2 of 12 Old 04-08-2008, 03:16 PM
Corkus's Avatar
Here are a couple of photos (scroll down). The "Switch for all Accessories" turns the grips on and the knob labeled "Heated Grips" is the Heat Troller for adjusting the Heated Grips.
I like the Heat Troller location ok, but I'm not as happy about the location of the Switch for all Accessories. It is not a bad setup, but I doubt any of it is going to stay that way when I figure out how I want to do this better.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #3 of 12 Old 04-08-2008, 03:21 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
Here's a cell phone shot showing the location of my switch.
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #4 of 12 Old 04-08-2008, 03:26 PM
My HotGrips + heated gloves Heat-Troller knob is on the clutch side hand guard. You can also see the matching silver dot just to the left of the gold steering stabilizer that is the top of the Heat-Troller for the jacket liner. The button on the right as pictured of the same tank front panel and just above and left of the plastic rivet is the garage door opener.
post #5 of 12 Old 04-08-2008, 09:18 PM
Stromtrooper.com Sponsor
Satch's Avatar
Not the greatest pic, but you get the idea. I used a pcv sprinkler elbow and inserted the switch inside. I ran the wires out the other end. I attached it to the mirror mount with zip ties. It's not necessarily the cleanest looking job, but it works great and I don't have to reach far to turn it off or on.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #6 of 12 Old 04-08-2008, 09:20 PM
mtlee's Avatar
Here's my setup - I put everything on the cable guide mounts in front of the handlebars. I used the corner of an old plastic multimeter case and a spare metal bracket to make the mounts. Nice for keeping everything out of the way, but this placement is not convenient for use when in motion. As I generally don't need to fiddle with the grip ON/OFF or the lights while moving, that's OK. But I do find I want to adjust the heated grips, and that location is not easy to reach while riding.
'07 DL650 ABS
'04 Yamaha V-Star 650 Classic Silverado (gone)
'04 Yamaha TTR225
'03 BMW F650GS (wife's)
'92 Honda XR250L
'86 Honda VT500c (gone)
mtlee is offline
post #7 of 12 Old 04-08-2008, 10:10 PM
silverstrom's Avatar
Not meaning to hijack the thread here, but why do you need the on/off switch for the grip heaters if you have the heat troller? I was under the impression that when I wire my symtecs with the heat troller the on/off switch isn't needed because there is a positive off on the heat troller. When I look at the symtec instructions I see the same thing. I'm just getting ready to install mine and want to be sure I understand it before I install it.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #8 of 12 Old 04-08-2008, 11:30 PM
I ride: '05 Yamaha FJR1300 abs & '14 Yamaha Super Tenere ES
wife rides: '15 Yamaha Super Tenere
MrVvrroomm is offline
post #9 of 12 Old 04-09-2008, 02:34 AM
Corkus's Avatar
Originally Posted by silverstrom View Post
...why do you need the on/off switch for the grip heaters if you have the heat troller? I was under the impression that when I wire my symtecs with the heat troller the on/off switch isn't needed because there is a positive off on the heat troller.
SS
SS, it depends on your Heat Troller if you have a positive on/off or not. It also depends on how you have it wired if an accessory stays on when the bike is shut off. Unless accessories are always off with the ignition, you need a switch to turn them off.
In my case, my Heat Troller has no positive off and my accessories stay on when the bike is off unless I swtich them off, so I need the switch.
I'd never trust those positive off trollers or any positive off accessories. If you forget to turn one off, you can kill your battery obviously, and I can forget anything given enough opportunities.
I'm rewiring everything to be always off when the bike is off. Then I won't need the switch.
(Unless I want to turn off all the accessories when the bike is running... :mrgreen
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #10 of 12 Old 04-09-2008, 07:19 AM
mtlee's Avatar
SS
In my case, I already had the switch installed, the controller wouldn't fit in the same area, and it was just easier to run a coupla wires from the switch to the controller rather than running all the wires over. Plus it gives me an absolute OFF that's visually obvious.
'07 DL650 ABS
'04 Yamaha TTR225
'92 Honda XR250L
mtlee is offline
