Tires that make me pucker! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-07-2008, 08:54 PM Thread Starter
No longer riding.
handyhiker's Avatar
I put a set of TKC 80's on my 1K. These tires were used but only had 900 miles on them. According to the side wall of the tires, max pressure is 35
psi. The factory tire pressure is 36/36 f/r for solo and 36/41 f/r for two up. I was out riding the other day and went into a turn some what aggressively. My back side puckered when the back of the bike seemed to skip/slid several times in the corner.
Here is some background... I am running 35psi in both tires, I have 10wt new fork oil filled to factory height, a SuperBrace, 1" raising link on the rear, the suspension is set to almost all the up.(about 1 notch soft both front and rear)
I have read all the threads I can find about these tires and all I can remember is that there were no problems on the way they handle. THESE THINGS SCARE THE SHIT OUT OF ME!!!!
Is there something I need to change in the bike set up to get better handling? I like every thing about these tires but the corners.
Any help or ideas? I know several have run these tires, what has your experiences been??
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #2 of 5 Old 04-07-2008, 08:58 PM
randyo's Avatar
factory pressure recomendations are for factory tires.... that are also radial ply, TKC80's are bias ply
I think you expecting too much from a knobby bias ply tire
I've never run the TKC80's but have run the similar Karoo T, more than adequate to get into it enuf to scrape hardware
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 5 Old 04-07-2008, 10:55 PM
MightyShep
Dude,
You're riding on tiny little squares of rubber what do you expect? They damn sure are not going to take a turn like a road tire. Be careful, you're one of the good ones and we'd hate to lose you.
post #4 of 5 Old 04-07-2008, 10:57 PM
805gregg's Avatar
Take out the raising links. I have an adjustable shock on mine when raised to the fullest it makes the rear kind of squirrely.
805gregg is offline
post #5 of 5 Old 04-07-2008, 11:17 PM
Scubadvr's Avatar
You may also want to lower the pressure a pound or two; you're running them at max.
[FONT="Tahoma"][I]Ride hard, stay safe![/I]
[SIZE="1"]DL650K7 Gray "Whee!"Strom [/SIZE][/FONT]
Scubadvr is offline
