oil showing on engine, a big problem? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-06-2008, 03:37 PM Thread Starter
Have about 6,000 miles on my DL1000. Looks like I have oil leaking out between the bottom part of the cylinder head and the transmission. Don't see liquid oil, but a dirty oily substance about 1/4 inch wide and about 3 inches long on the left side of the cylinder head. Is there a easy fix, or do I need to take it to the dealer? Should I just live with it, until I need tires, or seek help before then?
BOB56 is offline
post #2 of 3 Old 04-06-2008, 03:38 PM
Forum Admin
fatalerror's Avatar
Location: South West Florida, previously, South Africa.
Is it still under warranty? I would have a dealer look at that.
fatalerror is offline
post #3 of 3 Old 04-06-2008, 03:47 PM
cbrxxcess's Avatar
Send a message via Yahoo to cbrxxcess
If it is not under warranty I would take the tank etc off till you can see the motor clearly. Oil is funny stuff it can run down from a loose bolt or a gasket hit the area where the head bolts to the cylinder and then pool and run down from there. So I would do some close looking before I went to a shop or tore into the motor. Either way you need to get it stopped just waiting will generally never make anything better.
Keep the Rubber Side Down.
Jim
Present Rides
1986 XR600R,1986 VF1000R,1999 CBR1100XX,2006 CRF450X,2007 DL1000 V-Strom
[IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/Motorcycles/North%20American%20V-Strom%20Rally%202009/Canadamap.jpg[/IMG][IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/North%20American%20V-Strom%20Rally%202010/VisitedStatesMap.jpg[/IMG]
cbrxxcess is offline
