Installing electric cruise control - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 09-25-2014, 02:19 AM Thread Starter
I am wanting to install electric cruise control. I was thinking about this kit, but was wondering if I get this, is this all I will need? Do I need to buy anything in addition to this below?
Amazon.com: Universal Vacuum Cruise Control: Automotive
jmac731976 is offline
post #2 of 9 Old 09-25-2014, 02:43 AM
That appears to be a CCS-100 clone. It needs a vacuum canister and the handlebar control switch needs to be waterproofed. A switch mount has to be bought or fabricated. See more info at Murphs' CCS100 Cruise Control and the threads at Gearview-Cruise Control-Video and
Motorcycle Electronic Cruise Control | RVB Precision
https://www.stromtrooper.com/general-...tml#post748090
post #3 of 9 Old 09-28-2014, 05:53 AM Thread Starter
Thank You, as always!
post #4 of 9 Old 09-28-2014, 10:19 AM
The vacuum ports on the Glee are all occupied. You'll need to cut the present hoses and insert tee junction pieces in them then combine the hoses off those two tees with another tee. I'm pretty sure that involves more tees than come with the kit so you'll probably need extra vacuum tees.
post #5 of 9 Old 09-28-2014, 09:41 PM Thread Starter
Good to know-thanks!
post #6 of 9 Old 10-01-2014, 09:58 AM
I installed the rostra cruise control last fall. It is great on the highway. There is no vacuum canister to worry about.
ecape is offline
post #7 of 9 Old 10-01-2014, 11:16 PM
VSrider's Avatar
A question for those with CC. With a car you set it then take your foot off the accelerator. On a bike you're still gripping the throttle so doesn't that interfere with the operation?
VSrider is offline
post #8 of 9 Old 10-02-2014, 12:15 AM
I add some slack to the throttle cable and keep a loose grip. It's easy to add more throttle so I let up occasionally to prevent that.
post #9 of 9 Old 10-02-2014, 01:26 AM
larolco's Avatar
It works just like in a car. You'll feel the CC pick up and you can release the throttle. The only ways to cancel the CC engagement are engaging the brake or hitting the cancel switch. Holding the throttle won't keep the CC from engaging.
DRZ400SK17
larolco is online now
