Center Stand and Front Wheel Lift - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-21-2014, 03:23 PM Thread Starter
Anyone know how high the front wheel will come off the ground with a DL650 on the center stand, and the back weighted down? Thanks.
eweingarden is offline
post #2 of 10 Old 09-21-2014, 04:01 PM
knotzilla's Avatar
Enough that the front wheel will spin to remove if that's what you're looking fir
knotzilla is offline
post #3 of 10 Old 09-21-2014, 04:40 PM
jrnyer's Avatar
About an inch, maybe a little more.
Boycott SV Racing
jrnyer is offline
post #4 of 10 Old 09-21-2014, 04:41 PM Thread Starter
Thanks knotzilla. The reason I need to know is to see if I can let the fork tubes come down enough so there is space to re-route cables between the tops of the lowered tubes, and the top clamp. I want to take the little bit of strain off the cables which resulted from the install of Rox Risers.
post #5 of 10 Old 09-21-2014, 05:06 PM
One side at a time, take the spring out and slide the upper fork tube down. Do your reroute, put everything back. You don't need to lift the front. Prop under the engine to get full extension of the forks before removing the cap.
post #6 of 10 Old 09-21-2014, 05:36 PM
May I ask ewe :mrgreen: a question?
Being new to working on motos...wondering which cables youre re-routing and why.
Thanks,
John
Jproaster is offline
post #7 of 10 Old 09-21-2014, 08:23 PM Thread Starter
I installed the Rox Risers which move the bar both up and back towards me. When the bar moves back, it puts a little bit of tension on some of the cables and/or brake/clutch lines when the wheel is turned full right or left. Everything on the left has either enough slack, or a slight amount of tension when turned full right. For the right side, the brake line has a sharp bend and the throttle cable is slightly snug, when turned to full left. A number of Stromers have reported that re-routing the cables as described allows for bringing the bar back towards the driver even more, with no tension on any of the cables/lines. While I can move the wheel to full left and right, there is enough tug on those lines mentioned to make me want to re-route them.
PTRider - what are you doing to prop under the engine?
post #8 of 10 Old 09-21-2014, 09:46 PM
Thanks for the explanation.
post #9 of 10 Old 09-21-2014, 09:55 PM
knotzilla's Avatar
I installed the motech bar backs which is one inch up and one inch back. if I can recall the brake line bracket on the lower triple tree has to be loosened and re-angled to allow for enough slack in the brake lines. You will be happy with your new farkle, no more shoulder strain
post #10 of 10 Old 09-22-2014, 08:51 PM Thread Starter
Thanks for the replies. Mission accomplished.
