Rox 2" Rotating Riser - clearance for tools? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 09-19-2014, 11:24 PM Thread Starter
Question Rox 2" Rotating Riser - clearance for tools?
For folks that have installed the risers, anyone run into any issues with getting a socket allen driver to the bolts into the OEM handlebar grip on the fork?
Can you really torque those bolts enough with just a standard Allen key? Safe enough for riding, especially standing on the pegs and loading the bars vertically?
Anybody ran into any issues, any tips/tricks, let me know. Has anyone replaced the allen bolts with a standard hex head (I know, ugly, but you can wrench it from the side instead of the top).
Thx.
2002 DL1000
Madstad and Screen, Enduro Skidplate, Barkbusters, Hyperlites (front and rear), 17/43 sprockets, Reemis Exhaust, PCIII, Speedo DRD, OEM Heated Grips, Fork Brace and Lowered Pegs (AdventureTech), Givi top and side cases, Givi Engine Guard
maz_norcal is offline
post #2 of 15 Old 09-20-2014, 12:43 AM
When I installed mine I had the same issue.
What I did was tighten the rear (closest to the seat) bolts as tight as I could and left the front (closest to the windshield) bolts loose. I was able to pivot the risers to my liking with that and then access the front bolts.
Hope this helps but I am afraid that if you don't pivot the risers as close to the rider as I did it may not.
Good luck.
north_strom is offline
post #3 of 15 Old 09-20-2014, 12:59 AM
strompilot's Avatar
Pretty much that was my experience, too. It's been secure, except for the time I forgot to tighten the front bolts when I adjusted the bar angle. Doh!!
'09 DL650
strompilot is offline
post #4 of 15 Old 09-20-2014, 01:20 AM
Same problem I had. I bought these off Amazon and it took care of it. No hardware store in my area carried them.
http://www.amazon.com/Titan-Tools-St.../dp/B008BC3OI4
Psykledelic is offline
post #5 of 15 Old 09-20-2014, 01:54 AM Thread Starter
Thanks! I want to pull back the bars so tightening one side and then rotating and then tightening the front side will probably work.
It seems that allen keys are one of those tools that folks should just buy a few sets of common sizes.....folks cut them down, mount then in chucks, etc. Cheap enough to get the size I need and cut down to a stubby if necessary.
2002 DL1000
post #6 of 15 Old 09-20-2014, 02:17 AM
I tried cutting one down with a metal cutting blade but could hardly make a scratch. Unless you have the right set up, believe me, UPS is faster.
post #7 of 15 Old 09-20-2014, 07:41 AM
LordSmoke's Avatar
On the Wee, there is a specified order for torquing the bar clamps. There is a dimple in the clamps that is supposed to point either fore or aft. Then, IIRC, you torque the front, then the rear. With the risers, I turned the clamps, torqued the rear, rotated the riser into the desired position (I recall a rubber mallet might help), then torque the front. I also have a cut-down hex key in my toolkit lest they require an on-road snugging - they never have.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #8 of 15 Old 09-20-2014, 10:01 AM
Hammerdown77's Avatar
Yep, this is all pretty much the procedure Rox will recommend if you call them. Snug down the rear bolt all the way (or as much as you can and still be able to rotate the riser), rotate the risers where you want them, then torque the front one. This has held firmly on my Vee so far.
Livin' the dream
Hammerdown77 is offline
post #9 of 15 Old 09-20-2014, 10:26 AM
It's designed as "gapped joint". Just try to end up with similar gaps under the front & rear of each cap. Neither should bottom out. When you tighten the front bolts you are also stretching the rear bolts. Depending on friction under the caps the resulting bolt stretch and clamping force front & rear may not be equal, but they're far more than adequate.
dkayak1 is offline
post #10 of 15 Old 09-20-2014, 11:10 AM
Spec's Avatar
+1
Set them up right and tighten them down evenly then just loosen the front bolts, rotate into place and tighten up the fronts.
Spec is online now
Tags
risers , rox
