Longer sidestand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 09-19-2014, 11:28 AM Thread Starter
randyo's Avatar
Longer sidestand
my Vee has always leaned too much when parked, from day one
at first, I put lowering links on and that made it so that the lean was normal, but as I got used to the tallness and got my legs to stretch a bit better when throwing my legs over, I put the stock links back on when I installed my WP shock that is also a little taller
now my Vee lens about the correct amount when I have 2 blocks of 2x under the stand (3")
it is nice that I can park with the sidestand on the uphill side of the bike, but its becoming a bear to get it upright off the stand when I am straddling the bike
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 24 Old 09-19-2014, 11:54 AM Thread Starter
randyo's Avatar
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #3 of 24 Old 09-19-2014, 01:16 PM
Texas Oilman's Avatar
I cut my side stand when I lowered it, bad idea. But I welded a 1" nut on it when I raised it back up, now that I raised it another 3/4" I need more, my bike is doing the same as yours and I think I will cut the nut off and weld metal tube to the right length, maybe some flat stock for the foot, idk yet.
Texas Oilman is offline
post #4 of 24 Old 09-19-2014, 01:21 PM
On the bright side of things.. Looks like you have enough scrap in the background to build a solution to the problem and then some.. :-)
umfundisi is offline
post #5 of 24 Old 09-19-2014, 01:44 PM
Mine is mostly stock height. It leans too much. The first thing I did was to close the gap at the top of the arm, where it bolts to the frame. Then I put a bigger & thicker foot at the other end so it wouldn't sink on soft ground. It's about right, now.
But as you mentioned, I have to be careful where I put the stand down.
2007 DL 650 with assorted upgrades
Solo is offline
post #6 of 24 Old 09-19-2014, 02:35 PM
BabaAus's Avatar
Mine leans so much that I'm forever checking and rechecking to see if I bent the damn thing or something. The only time it ever looks "normal" to my eye is when it's parked amidst a bunch of other Stroms at one of our various rendezvouses.
BabaAus is offline
post #7 of 24 Old 09-19-2014, 03:49 PM Thread Starter
randyo's Avatar
there are scrap pieces of wood, and I gotta go thru the pile and weed dome of it into the dumpster. no scrap metal pieces, I have a ton of rebar, but I can think of better fabrication materials,
I have blocks of wood scattered where I am likely to park my bike on my property, you can't see the luggage rack, but I have a short chunk of 2x8 under a couple of bungee straps
at home, I am fine, I have compensated by having blocks readily available where I frequently park my bike. on the road, or rather off the road where I am more likely to be parking when not at home, my work brings me to woodlots houselots under construction, more often than not, very uneven ground, but more than once I have yelled to a construction worker on site to find me a scrap to put my kickstand on
I have been having thoughts of either designing a kickstand or maybe a attachment that is spring loaded, sliding ratcheting device that could extend or shorten the length of the kickstand with you foot as you lower it to match the terrain
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #8 of 24 Old 09-19-2014, 07:12 PM
I bolted a hockey puck to the kickstand foot, and trimmed the shape a bit larger than the foot profile. The thickness is just right, and only cost $1.00. :-)
Minder is offline
post #9 of 24 Old 09-19-2014, 07:27 PM
RWJC's Avatar
possibly but the foot adapter sold from Rick, and weld a 2.5-3" piece to the bottom of it....may be worth a shot..
04 DL650
RWJC is offline
post #10 of 24 Old 09-19-2014, 10:08 PM
teevee's Avatar
all of the bolt on ideas are great unless of course you have the oem centerstand in which case you're screwed
'08 DR650, '07 DL1000
teevee is offline
