I rolled into a dark parking lot and ..... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-19-2014, 12:40 AM Thread Starter
Rolled into a very dark parking lot, thought I had the sidestand down but couldn't really see, proceeded to jump off the bike instead of easing it over and of course dropped it there on the left side. So much for the nice silver paint (swmotech engine guards....yeah, wish I had the Givis that protect the tank).
So, a few tablespoons of oil spilled out from somewhere onto the pavement while the bike was down. I looked with my headlamp, didn't see any oil on the engine, no apparent casing cracks. Did the oil come out of a vent hole or....?
Bill in Roswell, GA
Roadscrape88 is offline
post #2 of 11 Old 09-19-2014, 02:10 AM
Chances are the oil came from the air box through the crankcase ventilation tube. It would be a good idea to look in the air box in case oil got into the filter.
post #3 of 11 Old 09-19-2014, 06:00 AM
What the expert said ^^^^
And there will be oil on the filter, but, unless there's a lot, not a problem.
I've seen this happen several times to dropped DL's. Oil level will be down a little, don't obsess about that, if it's near the mark, is fine.
Pete
PeteW is offline
post #4 of 11 Old 09-19-2014, 09:16 AM Thread Starter
The air filter is fairly new, replaced a few months before I bought it. But oil on the filter will come to sit in the bottom of the air box, creatling a nice sludge over time. Ah well, I needed a project for this evening any way.
Thanks for the input!
post #5 of 11 Old 09-19-2014, 09:24 AM
mowcowbell's Avatar
Don't feel too bad... I almost did the same thing the other day while stopping at a gas station. Thought I fully extended the sidestand, but it wasn't fully locked. Came real close to letting the bike fall over against the gas pump. That would have felt really stupid.
mowcowbell is offline
post #6 of 11 Old 09-19-2014, 10:01 AM
I've noticed when I fall down, oil gets in the air box.
How's that for confirmation?
post #7 of 11 Old 09-19-2014, 11:23 AM
MikeB's Avatar
Why are you hanging around dark parking lots? No good can come of that.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #8 of 11 Old 09-19-2014, 11:47 AM
rkruz's Avatar
I was expecting (and part hopeful) to hear..........I pulled into a dark parking lot with my Glock G30 at the ready and the lurking predators melted back into the shadows.
DL1000 2012
rkruz is offline
post #9 of 11 Old 09-19-2014, 11:30 PM Thread Starter
Actually the dark parking lot happens to be where my condo is in the complex due to trees blocking the lights.
Isn't there a drain plug at the bottom of the air filter box? Wonder if I should remove that for a moment to see if any oil drips out.
Also, to facilitate gas tank removal, why not put a stop valve at the top of the gas hose so the tank doesn't have to be drained?
Needless to say I filled the tank the day before I dropped the bike! Argh.
Yah, when I bought the bike a few weeks ago I was thinking my clumsiness would need the tank guard bars and not just the engine guard bars. Oh well. I want to get rid of that '09 tank decal anyway. Hate to replace the turn signal with another bulb unit, but don't have time to deal with the LED setup (the one that bends out of the way if hit) since I want to ride this weekend! Glue and tape will have to do for a few days.
post #10 of 11 Old 09-19-2014, 11:41 PM
There is a rubber plug over a short drain tube but you really need to look in the air box. Don't worry about fuel leakage when taking off the tank. The fuel pump plumbing stop flow when the pump isn't running. A few drops in the hose are all that will come out.
How do I remove the gas tank?
https://www.youtube.com/watch?v=gNwFb5WpznQ
