Search: rear foot peg - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-02-2008, 04:00 PM Thread Starter
BV1
BV1's Avatar
That was a bit frustrating. I tried different combinations and I kept getting the error the word is too common.
I am trying to find out if my Wee has rear passenger foot pegs from the factory. My 2K5 does not have any on it.
Any idea where I can buy some? I can't even find the OEM diagram on www.bikebandit.com.
Thanks guys,
-Steve
"There is no replacement for displacement"
Lets debate this over 6000 RPM and 15 psi.
2005 V-strom 650 Silver
1982 Yamaha Seca Turbo (Well Farkled.)
BV1 is offline
post #2 of 8 Old 04-02-2008, 04:16 PM
It does. The footrest section of the fiche is the one to check. Post in the wanted section. Maybe somebody who took theirs off will sell.
post #3 of 8 Old 04-02-2008, 06:08 PM
Corkus's Avatar
Pat, thanks for the fiche. Is there a spec on part #18 on that fische? That is the bolt I need to swap out for a longer version so I can add higher rear footpegs.
Is that fiche online? From Ron Ayers?
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #4 of 8 Old 04-02-2008, 06:37 PM
09106-08074 is the part number. Fiches are available from Ron Ayres, Oneida Suzuki, MRCycles, Bikebandit etc..
post #5 of 8 Old 04-03-2008, 09:46 PM Thread Starter
BV1
BV1's Avatar
Thanks! Someone took mine doh, now I need to find some.
-Steve
BV1 is offline
post #6 of 8 Old 05-17-2008, 10:22 PM
SenordrummeR2's Avatar
I just searched the entire Service Manual to find out what the torque limit is for attaching/tightening the rear foot peg bolt, but I can't find anything. Does anyone know how tight is supposed to go? My right side is loose after a tip over.
"Pools are great for holding water." - Dave, "Hot Rod"
'04 DL650 - Black : Dualstar Heater Grips, SW-Motech Crashbars, Pro-Taper 7/8 bars, Suzuki Top box and side cases, 16T Suzuki Front Sprocket, 47T Rear JT Sprocket
[URL="https://www.stromtrooper.com/showthread.php?t=23567"]Stromtrooper Offroad Club Member #23[/URL]
SenordrummeR2 is offline
post #7 of 8 Old 05-18-2008, 10:08 PM
Suzuki's chart for 8mm grade 7 bolts says 16.5 lb-ft. That's interesting because 16.5 is what is recommended for a lot of 6mm bolts including the front fork tube pinch bolts. I always thought that was way too much. Ditto for 72.5 lb-ft on the rear axle and 25.5 lb-ft on the bolts often used to install engine guards.
post #8 of 8 Old 05-19-2008, 11:47 AM
BadKarmaPa's Avatar
I have seen engineering specs that say 1/4 turn past where the bolt is seated for common hardware.
This would not apply to hardware with non-standerd threads, like Acme threads or pipe threads, or things like axle bolts where load on the bearing race is important.
K7 Wee
Off-road member #26
BadKarmaPa is offline
