rear brake pedal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-16-2014, 09:36 PM Thread Starter
kmsz1969's Avatar
rear brake pedal
Since I installed a pair of new SW Motech footpegs it's difficult to use the rear brake because the pedal it's higher than the footpeg. I tried to adjust it the best I could but I'm at the limit and it's still high. When I use boots I find a little difficult to use the pedal.
Does anyone knows if there is any adjustable brake pedals in the market?
Any suggestions?
Thank you...
kmsz1969 is offline
post #2 of 10 Old 09-16-2014, 11:21 PM
i would have to look at mine but i think you can file or cut off a bit of the threaded shaft and adjust it a little more.
invisabiker is offline
post #3 of 10 Old 09-17-2014, 06:39 AM
Yep, had to do that on my K6, my L2 with ABS is a bit more forgiving.
Pete
PeteW is online now
post #4 of 10 Old 09-17-2014, 11:42 AM Thread Starter
kmsz1969's Avatar
Yes... You know how annoying it is to have to lift your foot to properly hit the pedal instead of slightly lift the instep. When you're in an area with many curves or traffic is a big hassle.
Itīs common to find after market shifters but not brake pedals, I donīt know why!
I will try to do what you suggest and send a picture of the job!
kmsz1969 is offline
post #5 of 10 Old 09-17-2014, 01:42 PM
Are you sure the nuts were completely loose when you were trying to adjust it? I fitted lowering blocks (on a different bike, I have them on the V-Strom too, but the V-Strom pedal moves with the bracket) and it was no problem to adjust the pedal to be an inch lower.
Gustavo
Gustavo is offline
post #6 of 10 Old 09-19-2014, 11:01 AM Thread Starter
kmsz1969's Avatar
As I saw, that Push rod has just an small thread so thereīs no much to regulate. Iīn in the limit but the pedal it still high. Someone told me to heat the pedal and bend it to get the desired position...
kmsz1969 is offline
post #7 of 10 Old 09-19-2014, 12:40 PM
Spec's Avatar
The rod has threads on both ends. You rotate the rod to thread it in/out of the master cylinder there's quite a bit of adjustment.
Spec is offline
post #8 of 10 Old 10-02-2014, 12:30 PM
soberjoe's Avatar
I just pretzled my rear brake pedal last evening - wrapped it around my SW Motech peg - managed to straighten it well enough to get out of the bush and ordered a new one this morning - $75.00 - OUCH! - I will post my adjustment-findings when I receive and install the new pedal. Like the OP I found the pedal to be too high in relation to the SW Motech pegs.
Joe
Today is the only day that truly matters. Here's hoping that yours is beautiful.
2001 Honda 750 ACE - written off May 25, 2014
2014 V-Strom 1000 - Purchased August 25, 2014 - first ride September 2, 2014
http://advjoe.ca/
soberjoe is offline
post #9 of 10 Old 10-02-2014, 03:15 PM
Rolex's Avatar
Originally Posted by soberjoe View Post
I just pretzled my rear brake pedal last evening - wrapped it around my SW Motech peg - managed to straighten it well enough to get out of the bush and ordered a new one this morning - $75.00 - OUCH! -.
Sound like you need a brake snake, Google it.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #10 of 10 Old 10-02-2014, 03:49 PM
Moved to the general forum. All 650s have the same rear brake pedal.
