HELP!! OIL Spraying out of Filter!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 03-30-2008, 08:16 PM Thread Starter
Help all, just changed my filter for the second time but this time I think I tightened the filter too tight as the rubber gasket looked like it was bulging on the bottom. I loosened it up and tried again and its' still spraying fast as well.
HELP!!! Should I just put the old filter on there for now as I may have ruined the seal on the new filter?? I'd have to even go get more oil as I only have one quart left on me. ...arrggh....not sure what to do ..any advice appreciated!!
OldIronsides is offline
post #2 of 15 Old 03-30-2008, 08:21 PM
$tromTrooper
MTNAdventureRider's Avatar
Have you checked to see if the old rubber gasket was stuck to the engine? You may have a double gasket causing your troubles.
Big John
2007 DL650 - Gone but not forgotten
MTNAdventureRider is offline
post #3 of 15 Old 03-30-2008, 08:22 PM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
Nine times out of ten this happens when the old filters rubber gasket stuck to the engine block. Pull off the new filter and scrape the old gasket off the block. Put the new filters back on (doubt it was damaged) and you are good to go.. other then the mess and needing more oil of course.
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #4 of 15 Old 03-30-2008, 08:24 PM
stevet's Avatar
Time for a new filter.
OEM filters, follow the directions to make two full revolutions after the gasket first makes contact, watch carefully for that first contact. After market filters, the old adage of 3/4 turn after gasket contact should be sufficient, but check to make sure.
OEM filters have a different o-ring seal gasket than after market filters. One is round, the other square- just can't recall which is which.
At least is a sub-$20 learning lesson, a new filter and a couple quarts of oil. That's life.
(edit)
Oh, and like the other guys said, too, if you double gasketed. Did that once on a car, lost three quarts VERY fast. What a mess, driveway is an incline and the oil ran...
Steve.
Twin Cities, MN, USA
-Me, Steve T.
stevet is offline
post #5 of 15 Old 03-30-2008, 08:28 PM
16171
One time while changing my oil, I forgot to put the "oil fill plug" back in after filling with oil.
Take my advice, NEVER DO THAT!!!
I'm still cleaning oil spray off the wall of my garage
post #6 of 15 Old 03-30-2008, 08:35 PM Thread Starter
IT was the 'ol old gasket stuck on there and I didn't notice as it was just getting dark when I did it. That'll teach me do blow off changing it til dusk so I don't lose any riding hours.
Panic set in and now I'm all better thanks to you all. I think I only lost about a quart of oil in the fiasco.
Whew...I feel like a dummy, but yes, a dummy who is only about 10 bucks and good lesson learned lol.
thanks again
post #7 of 15 Old 03-30-2008, 09:06 PM Thread Starter
Ok...update on my idiocy..lol
Three cheers for living in Florida as we have ample sand here. All I have to do is go out to any corner and bucket up all I need. My driveway is also on an incline. I figure I lost about a quart and a half...and sure enough it went running downhill...all nice and hot. So all the easy access sand sure came in handy lol.
post #8 of 15 Old 03-30-2008, 09:08 PM
Diver9543's Avatar
Yeap, lots of pressure. At least the funnel that was still in mine kept a lot of the spray localized. :rolleyes:
Jerry C.
K7 1000
GL1500SE
Vee for Me - SE for We
Diver9543 is offline
post #9 of 15 Old 03-30-2008, 11:28 PM
MeefZah's Avatar
I've forgotten to put the damn drain plug back in. I'll start refilling with fresh oil and suddenly this helluva puddle appears underneath the 'Strom. I've noticed I'm becoming really scatterbrained lately.
I've also noticed I'm becoming really scatterbrained lately.
Damn.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #10 of 15 Old 03-30-2008, 11:28 PM
morm914's Avatar
I work as a mechanic and every old filter I take off I peel the gasket off of it so I know it came off with the filter.
2006 DL650
1972 XS650 Hardtail
1995 250 Ninja ([I]Wifes bike[/I])
morm914 is offline
