pro taper bar bar ends - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-30-2008, 02:44 PM Thread Starter
Just put on pro-tapers but now the oem ends don't work.
Options? Fixes?
I like the oem hand guards just fine and would like to get the stock ends to work.
becoyote is offline
post #2 of 9 Old 03-30-2008, 08:46 PM
No longer riding.
handyhiker's Avatar
I have the ProTapers with the stock ends. You need to grind down the nuts with the built on washers. also you can change out the rubber with 5/16 fuel line. It is not difficult with a bench grinder. Take you time and you will be fine.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #3 of 9 Old 03-30-2008, 09:55 PM
mhoffm's Avatar
https://www.stromtrooper.com/forums/s...ght=rubberdown
Hope this link works. Take a look at the picture Rubberdown posted about grinding down the nut and rubber. If the link does not work, search by his name and look for the Pro taper post.
mhoffm is offline
post #4 of 9 Old 03-30-2008, 10:17 PM
RedAnt's Avatar
Conversation in progress...
I end up buying the MSR ATV HI-Bend steel bars, because I knew I wanted a throttle lock. I ended up with a ThrottleMeister one, after not being able to get a KAOKO one in time for my trip last fall.
My step brother gave me a set of Pro Taper SE bars for Christmas this year and I re-started the search.
Eventually I came across the following site, with a little information on aluminum bars and bar weights.
http://www.manicsalamander.com/throttle_lock.htm
Someplace on this site I found a request for feedback on products and made a case for a minimally weighted Throttle lock for the ProTaper bars. I quickly got a response that he had one in development. We went back and forth a little on them before a very snowy winter limiting my riding, so I've not gone ahead with the tests. It seemed to me that he was about to release this as a product, so I suspect it's available if anybody asks.
I have not used the product, but it does seem from reading about it that it would be a little nicer than my Throttle Meister setup.
DL650K6, MadStad adj shield, Givi e45 & e36, gpsmap 76CSx, Pat Walsh skid plate & bars, Sargent seat
2004 DRZ400S
[URL="http://www.sr.unh.edu/~rea/stromtrooper/2007/Strom_Range.png"]My 2007 Range map[/URL]
RedAnt is offline
post #5 of 9 Old 03-30-2008, 10:29 PM
Scarlett Harlot's Avatar
I went with the 5/16 fuel line to reinstall the bar ends on my ATVMids. It cost me about 98 cents in smaller washers, lock washers, and new nuts. I reused the stock bolt. Whole job took 10 minutes.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #6 of 9 Old 03-31-2008, 05:06 PM
DRAGON997's Avatar
I have the Protaper SE ATV high bars and Cycra handguards.
You really dont need the bar end weights in my opinion.
Dump the Suzuki salad bowls and get gome protection that will work.
Johnathan [url]www.motovan.com[/url]
07 1K
08 KLR 650
06 CRF 250 X
09 KTM 300 XCW
DRAGON997 is offline
post #7 of 9 Old 03-31-2008, 05:11 PM
Sudzz's Avatar
That's what I did as well. Plus I was able to save all the stock hardware.
[SIZE="2"][SIZE="1"]DL650K7 - Blue
Madstad Bracket = Awesome!
Emgo Mirrors = Work and Look Great
Cortech Sport Tailbag = Very nice
Cortech 10L Tankbag = Another nice piece
MSR Dominator ATV Hi Bars = Give the bike a whole different feel
Suzuki Gel Seat = Best so far but still not 100% for me
Bestem (Ebay) 2012 42L Top Case = Best bang for the buck!
Modified V-Stream Windshield = Works well
Zumo 550 = Brilliant!!![/SIZE][/SIZE]
Sudzz is offline
post #8 of 9 Old 03-31-2008, 06:36 PM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
I have some aftermarket hand guards that required no tweaking at all to fit to the new bars. Take it as a sign to get some good lever savers!
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #9 of 9 Old 03-31-2008, 09:38 PM Thread Starter
I had already ground down one side but I guess I went too far because it wouldn't work when I put it back together.
I'll try the fuel line trick. That is a good idea
If that doesn't work I'll be off to the after market.
becoyote is offline
