Need a windshield cut down...suggestions? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 31 Old 09-10-2014, 09:59 AM Thread Starter
cpr4life's Avatar
I bought a 26" windshield that was perfect with my stock seat, but my custom seat is a bit lower & now the top edge of that shield is right in my line of vision.
I'm positive cutting it down 2" would be perfect but I would never attempt this on my own. So what type of businesses do you guys think may do this kind of thing?
2007 Honda ST1300
2007 Suzuki DL1000
2003 Suzuki DL1000 (sold)
2000 Yamaha Road Star 1600 (sold)
2004 Moto Guzzi Breva 750IE (sold)
2006 Kawasaki Vulcan 1500 Classic (sold)
2001 Suzuki Volusia CT50 (traded)
1986 Honda V65 Magna (sold)
1972 Honda CB350 (rode it 'till it dropped)
cpr4life is offline
post #2 of 31 Old 09-10-2014, 10:20 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
If you strike out looking for a company to do it, you can do it yourself with some simple tools. Or, a buddy with simple tools.
Check out this video.
Cut Down Your Motorcycle Windshield
richlandrick is online now
post #3 of 31 Old 09-10-2014, 10:36 AM
trapperdog's Avatar
Most retail plastics Co's will also do it. I've had a Co out here called a Tap plastics cut one years ago.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #4 of 31 Old 09-10-2014, 11:00 AM
RCinNC's Avatar
+1 on TAP Platics. Great to do business with. In fact, they have great customer service, and if you contact them, they may tell you how to have it cut, even if they aren't going to be doing it themselves.
A metal fabrication shop may be able to do what you're asking. When I cut acrylic plastics, I use a metal cutting blade (lots of TPI) in a sabresaw; cut very slow, and use tape over the cut line. If they have a variable speed metal cutting bandsaw (the kind you might find in a metal shop), they could probably do it for you, though I doubt if they would take any responsibility if it went badly.
RCinNC is online now
post #5 of 31 Old 09-10-2014, 11:27 AM
Kurgan's Avatar
I've done a few using a Dremel with a rotozip type bit and then sanded/filed the overall edge to perfection, but that's the hard pain-in-the-ass way. You want a bandsaw or scrollsaw with a real high TPI. You'll still need to do some sanding to smooth out the cut edges (use a foam sanding block/sponge as found at Lowes), but it's very doable.
Jim
Kurgan is offline
post #6 of 31 Old 09-10-2014, 12:08 PM
ok.. I will be the one to make the joke..
How about a booster seat.. :-)
umfundisi is offline
post #7 of 31 Old 09-10-2014, 12:33 PM
Craig Jackman's Avatar
I cut mine down with a hacksaw. Masked off the area of the cut, then took a string and a Sharpie to get the curve even. Carefully cut it freehand, following the line from each side halfway. I haven't even sanded it down yet, but a little sandpaper wouldn't hurt. My buddy the glazier is totally offended by this and insists I bring it by to spend 30 seconds with his glass sander.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #8 of 31 Old 09-10-2014, 02:06 PM Thread Starter
cpr4life's Avatar
Thanks for the suggestions...except for the booster seat, which is useless.
Anyway, I'll have to check around because there's zero chance it will come out well if I try it on my own.
2007 Honda ST1300
2007 Suzuki DL1000
cpr4life is offline
post #9 of 31 Old 09-10-2014, 02:35 PM
heh..
post #10 of 31 Old 09-10-2014, 08:18 PM
Give it a go. I just cut the windshield on my Harley Road King, and it came out great. I used a saber saw with a 22 tooth blade. I masked off both sides of the shield; then made a template out heavy poster paper by tracing the existing edge of the shield so the curvature would be the same. I trimmed the template with scissors on the traced line, then traced that onto the taped area. I took my time with the saw, then finished with 200 and 400 grit wet sanding blocks. Super easy, and it looks great. I did this with the shield on the bike for stability when cutting. Trust me, if I can do it, you can do it. Back in the day, when I ran a drilling rig, my hands told me I had a touch like a gorilla with a migraine!
deuce is offline
