sprocket change- can't get the big nut off!!! Help!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 58 Old 03-29-2008, 03:08 PM Thread Starter
stevet's Avatar
Swapping the 15t to a 16t. I've got the sprocket washer bent back away from the nut face, new Harbor Frieght 1/2 drive impact gun running is lefty-loosy mode, air pressure set at 90psi (max per gun, which claims to torque to 250 ft lbs), gun running in it's highest power setting (1-4, set on 4) and that darn nut will not even budge. Run and run and run and run...
Tranny is in neutral, but the wheel is held in place up off the ground (centerstand) by a block of of wood, so the tire isn't spinning at all.
Thoughts?
Tried the socket wrench version last night, not effective either.
Until I get some info, I'm heading for the lowering link install part of my day.
Thanks.
Steve.
Twin Cities, MN, USA
-Me, Steve T.
stevet is offline
post #2 of 58 Old 03-29-2008, 03:17 PM
Highveelocity's Avatar
Hmmm. Got mine off with the same gun. Is it full on reverse mode? Sometimes if you don't get the lever all the way over, it won't get full power to the gun.
'05 Silver Wee, Givi crash bars, Scotts dampener, JC top box, Battlewings, Homemade fork brace, GSXR calipers with homemade brackets. TCI Outback luggage System, Mr. Eds Moto custom seat
http://s288.photobucket.com/albums/l...ty/56%20Chevy/
Life, repression, and the pursuit of tax money
Highveelocity is offline
post #3 of 58 Old 03-29-2008, 03:19 PM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
Take out the block of wood and let it move.
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #4 of 58 Old 03-29-2008, 05:02 PM Thread Starter
stevet's Avatar
Thanks guys, will recheck the gun direction lever (free spins counter clockwise) and will just set on center stand without the wood under the tire (between tire and floor). I'll report back.
Steve.
-Me, Steve T.
stevet is offline
post #5 of 58 Old 03-29-2008, 05:32 PM
Red Loctite is applied. Get out the torch. You need to heat it and use the impact wrench while still hot.
post #6 of 58 Old 03-29-2008, 07:59 PM
Bisbonian's Avatar
Air tools is something it pays not to skimp on. I've had harbor freight air tools and the ones I've had are a joke.
My 1/2" drive Chicago Pneumatic impact took that nut off like nobody's business, red loctite or not. My harbor freight cut-off wheel stops turning if it even thinks it's close to the work surface.
I think I paid around $100 for my impact, well worth it.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #7 of 58 Old 03-29-2008, 08:15 PM Thread Starter
stevet's Avatar
Heat- got it.
Well, my Chicago Pneumatic version cost me a whopping $19. Will try the heat tomorrow. If that doesn't do it, then I'll take it back and swap for another.
Steve.
-Me, Steve T.
stevet is offline
post #8 of 58 Old 03-29-2008, 08:22 PM
whistler's Avatar
SteveT, I used the cheapest Lowe's Kobalt 1/2" drive impact wrench, but it was rated at 350 ft lbs. Tranny was in neutral, bike on centerstand, rear wheel chocked with a long piece of round stock between the spokes and resting on the swingarm. Mine was Red Locktite'd on, but the countersprocket nut spun right off when I pulled the trigger.
I hope you don't need heat, but if you do, be precise and wrench it while it's hot.
2019 Yamaha Tracer 900 GT (Annabelle)
2013 Suzuki V-Strom DL650 (Juliette)
2013 Yamaha FJR 1300 (Rachel)
2008 Suzuki Bandit 1250S (Fiona)
2006 Honda VFR800 (Jenny)
2005 Suzuki V-Strom DL650 (Hannah)
2003 Honda Shadow Sabre VT1100 (Veronica)
whistler is offline
post #9 of 58 Old 03-29-2008, 08:56 PM
V-Strom Ry's Avatar
I've never done this myself, but a couple of comments:
1) I'd be careful with putting heat to that part - the countershaft seal may not care for it.
2) If this is the factory sprocket, it may have some threadlocker on it, but just because it's red doesn't mean it's red Loc-tite. The factory uses a threadlocker which is red but comparable to Loc-tite's blue stuff. It can be broken loose without using heat. Permanent threadlocker is usually only used on crucial engine internals.
Have you tried a big 'ol freakin' breaker bar on it?
V-Strom Ry is offline
post #10 of 58 Old 03-29-2008, 09:01 PM
jackpiner57's Avatar
I agree, don't use the torch. Use a better impact gun with at least 125 psi. Mine came right off.
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
