Windshield Care - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 03-26-2008, 12:23 AM Thread Starter
NordStrom's Avatar
Location: beautiful Vancouver, on the Wet Coast of Canada
Windshield Care
Not that I mind, since I've got a Givi screen on order, but I've managed to scratch the stock shield in pretty short order. Had a screen on my previous bike but never had a problem scratching it while cleaning.
I used Plexus plastic cleaner and a microfibre cloth. The cloth looked clean but there's some chance it may have picked up a bit of very fine grit in it. After cleaning, the windshield had a lot of very fine scratches on it. Bad choice of cleaner? or cloth? or blame some grit?
I think my last shield (OEM Honda cruiser product) was a Lexan (polycarbonate) shield; what is the stock Strom shield made from? What is the Givi shield made from?
Stromtroopers with newer Givi shields: what have you found works well to clean your shield and what has led to any problems?
If you know of a previous thread that has answered these questions, I'd be happy to be directed; I searched but couldn't find anything. Is it not possible to search for a combination of words?
NordStrom is offline
post #2 of 14 Old 03-26-2008, 07:38 AM
Faulkner's Avatar
There is something about the stock windshield, but it seems to scratch very easily. I use Pig Snot cleaner with microfiber cloths on my Harley windshield with no problems at all. Used the same stuff on my new Wee and it left some small surface scratching. The Suzuki shield just seems to be soft or something.
2014 HD Electra Glide Ultra Classic
2008 Suzuki DL650 V-Strom (Flat Black Member #18 )
2007 HD Electra Glide Ultra Classic
2003 Suzuki Volusia
Faulkner is offline
post #3 of 14 Old 03-26-2008, 07:58 AM
jwt
jwt's Avatar
My stock screen scratched easily also. I have the "cleaning plexiglas windshields" sheet that came w/ my cee baileys screen here, and it says to make sure to rinse and use your bare hand to dislodge any caked dirt or matter, and rinse and dry with a clean damp chamois. They also recommend soft flannel as a wiping medium. It states that acetone, benzine, carbon tetrachloride, fire extinguisher fluid, paint stripper or laquer thinner, and especially, window sprays or kitchen scouring compounds will damage the shield. I may have screwed my stock one with the window sprays. I can't imagine anyone using some of that stuff though. Meguiars mirror glaze mgh-17 plastic cleaner or meguiars mirror glaze mgh-10 plastic polish are recommended products for my plexiglas 'baileys.
"I believe the most damning thing that can be said about muslims is saying you're afraid to say anything."--Penn Jillette
Pointless Profanity Club member #10 ****face.
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
jwt is offline
post #4 of 14 Old 03-26-2008, 08:10 AM
SCraig's Avatar
For "Normal" cleaning I use Eagle 1 20/20 Glass Cleaner which is alcohol-based as opposed to ammonia-based. Most of the glass tinting films recommend not using ammonia-based cleaners since ammonia is supposedly hard on plastic.
I've also started using Novus plastic polish for the past year or so and love it. About once a month I polish my screens with that and it takes all the small scratches out. Novus and Plexus are two of the brands recommended by Zero Gravity and they do work pretty well.
Scott Craig - Nashville, TN
SCraig is offline
post #5 of 14 Old 03-26-2008, 08:22 AM
Lemon Pledge
I use lemon pledge on my windscreen and visor. Spray on, then using a very soft cloth, or micro fiber, spread it all over the windscreen. Let it set 1-2 min then using a dry/new cloth polish it up. Badly scratched may take 3-4 attempts. I have used this for 15 years. Same visor for 3 years..
Bonuses : The citric acid dissolves bug impacts, water beads and flows off.
it leaves a nice lemony smell
riding a bike you can forget many things, thats why i ride a bike...
novascotia is offline
post #6 of 14 Old 03-26-2008, 10:34 AM
In the aviation community the windscreens are very critical to safe flight and crazed or scratched windscreens are murder if landing into the sun.
All the research out there and the best alternative always comes back to lots of clean clear water first (maybe using your hand lightly) to eliminate as much of the fine particulates as possible, then follow with cleaner of your choice. There is not much better than Plexus or Honda's polish (out of production) for this purpose. I have had good results with some waxes like pledge, but they do build up over time and I have heard that the petroleum distillates in some of these may make your plastic brittle.
For cleaning plexi or lexan, get the Mequirs (sp) Polish or Cleaner to help eliminate light scratches (read bottle to determine which one for your level of scratching). It will also eliminate wax build up.
Always clean vertically (up and down) never in circles or horizontally (side to side) as these make scratches more evident visually.
StromFlyer is offline
post #7 of 14 Old 03-26-2008, 10:40 AM
Living the Stereotype
Stromin'Nroman's Avatar
I use LP* record cleaning fluid: 1:10 soluton of denatured alcohol and distilled water in a spray bottle and lots of it. I wipe it down with flannel then apply Rain-X.
I don't do it that often, I think people tend to try to keep their windsheilds too clean which, I believe, is the primary cause of scratching.
* LP Records, once predominant, are now a mostly obsolete form of music distribution. They can be found in many thrift stores and at yard sales hidden inside kitchy 12" square cardboard posters. It is in the form of a usually black, 12" diameter vinyl disk with a 1/4" spindle hole in the center. Playback devices still exist for this format but are found primarily in the recording studios of Urban Music producers and the basement apartments of Jazz Nerds. When played back on quality gear, the LP produces a lush soundscape punctuated by pops, scratchy hiss and musical phrases repeated arbitrarily until human intervention intervenes. This is where the expression, "Shut the hell up you smarmy weasel, you sound just like a broken record," comes from. The LP record pioneered the phenomenon of the hidden backwards message, discovered with pharmecutical inspiriation and a reversable turntable by college students in the late nineteen sixties. Musical palentologists have found that chief practitioners of this practice were rock groups like, The Beatles, The Pink Floyd and Winky Sphinkter and the Skidmarx. Nowadays, LP records are often heated up just enough to be molded over one's head for use as a helmet, suitable for riders of certain air-cooled V-twin, powered motorcycles.
Source: Wikipedia.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #8 of 14 Old 03-26-2008, 12:11 PM
mtlee's Avatar
I also use Pledge, works great.
If you want to get the scratches out, I've had tremendous success using Brasso. And if some of the scratches are deep, I'll put a soft cloth rag on my orbital sander and use that to apply the Brasso. Worked on my windshield as well as my faceshield.
Brasso, however, does not leave a nice, lemony scent. Use outside if at all possible.
'07 DL650 ABS
'04 Yamaha V-Star 650 Classic Silverado (gone)
'04 Yamaha TTR225
'03 BMW F650GS (wife's)
'92 Honda XR250L
'86 Honda VT500c (gone)
mtlee is offline
post #9 of 14 Old 03-26-2008, 12:41 PM
SCraig's Avatar
Actually Honda Polish isn't truly out of production. It's still there, still available, it just doesn't say "Honda" on it any longer. Honda did discontinue it. The company that actually made it for Honda knew a good thing when they saw it so it's still sold under their name. Same can, same colors, just doesn't say Honda on the can.
SCraig is offline
post #10 of 14 Old 03-26-2008, 01:12 PM
Strom Yooper's Avatar
I used the cleaner that came with my Cee Baily screen on my stock screen w/microfiber cloth (new out of the bag). The stock screen ended up with tiny scratches, was worse than when I started?
Strom Yooper is offline
