Custom top case wall mounted holder in the garage ideas - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 08-23-2014, 10:05 PM Thread Starter
Mastery's Avatar
Anybody build some kind of custom rack to hold your top case in the garage? I seem to ride with mine off about 50% of the time when I don't need it. Just looking for some ideas to maybe build a holder of some type to mount on the wall to hold the top case so it's not sitting on the floor or precariously on one of the bar stools.
Pics would be nice if you have them. :mrgreen:
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #2 of 8 Old 08-24-2014, 02:16 AM
When my Givi E460 isn't on my Wee, I mount it on this stand. It locks on securely and it's mobile so I can store the Givi in various locations. :mrgreen:
pic below
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
post #3 of 8 Old 08-25-2014, 01:13 PM
If it's a Givi, the hard parts (the bottom mounting bolts and the latch) could be mounted to a piece of wood, and that could be hung on a wall. I think I had read that Givi could supply that hardware separately, but I'd be on the lookout for a cheap, trashed set of racks.
brokeagain is offline
post #4 of 8 Old 08-25-2014, 08:04 PM
You could build a wall mount using a couple of screws and this part:
GIVI Z124 Pyramid Attachment Clamp For Monokey Topcases - PCA - Premier Cycle Accessories
or the complete kit:
Topbox Mounting Kit for Givi Monkey Boxes - PCA - Premier Cycle Accessories
Although when you consider how far it will stick out from the wall, a simple shelf might work as well or better.
2012 DL650
Joe Menting
Semper Fi
[URL="www.st-owners.com"]www.st-owners.com[/URL]
Lost Dutchman is offline
post #5 of 8 Old 08-27-2014, 02:33 PM Thread Starter
Mastery's Avatar
Yeah, figured throwing a shelf up is probably the easiest way. Just looking for maybe some cool suggestions. I built a custom rack to hold the tour pak of my Ultra on the wall, figured I'd do something similar. I'll give it some thought.
Mastery is offline
post #6 of 8 Old 08-28-2014, 10:41 AM
Craig Jackman's Avatar
Yes you could buy another Givi mounting plate and Mcgyver it to the wall, or you can just go to Wal Mart and buy a shelf. If you're really paranoid, a shelf and a bungee cord to keep it on.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #7 of 8 Old 08-28-2014, 12:33 PM
Kurgan's Avatar
I built this for Givi cases and what ever other bike gear. Just one shelf for now, may add another later. Overkill, nahhh, just good enough and fun to make. Be a a lot cheaper to just get 12" deep shelf brackets and put a piece of 16" deep plywood on it, but that wouldn't have been as fun.
Jim
Kurgan is offline
post #8 of 8 Old 08-28-2014, 04:21 PM
Similar project here, except I am mounting side cases to the walls of my enclosed trailer.
I have purchased mounting kits for each type of bag, and used appropriate screws/wood to attach them to the wall. no reason you could not do this with a top box. infact my GIVI E41's and my top boxes use the same mounts.
OldMedic
Sick and Stupid people keep me employed....
Bikes: 81 Yamaha RD350(x2), 82 Yamaha RD350, 82 Honda FT500, 84 Yamaha FJ1100(x2), 85 Yamaha RZ500, 86 Yamaha SRX600, 03 Suzuki Burgman 650, 03 Suzuki DL1000, 08 Suzuki DL650, 14 Suzuki DL1000ADV.
OldMedic is offline
