Chain Lube - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 08-18-2014, 01:24 PM Thread Starter
jeffvader's Avatar
Chain Lube
I adjusted the chain yesterday as there was too much slack, and boy what a difference it made.
I want to clean the chain before I head out on my trip in a few weeks. Any recommendations on the best lube out there? I have a guy I've been learning some stuff from, but he's also the kind of guy where everything he buys/does is "the best." So I tend to take him with a grain of salt. I don't need everything in my life to be a competition.
You're Mr. Stevens?
jeffvader is offline
post #2 of 24 Old 08-18-2014, 01:49 PM
zekester63's Avatar
Asking about chain lube is about like asking which oil to use... you'll get lots of different opinions from everyone, and reasons why their answer is right. If I were you, I'd search a little on this forum and come to your own conclusion based on what you find. You'll find everything from used motor or tranny oil to WD-40 to all the popular brands of chain lube. Oh, and those that do nothing.
I think the most important things are 1) don't clean excessively or too often or with harsh solvents, 2) don't use a stiff brush (or any brush except maybe a tooth brush) when you do clean it, and 3) keep it lubed (I lubed every tank, many lube every other tank and after riding in rain).
Personally I think most lubes are "fine" - but that it's a matter of personal preference on how it goes on, how sticky or messy it is, how much riding off road you do, the cost, etc.
zekester63 is offline
post #3 of 24 Old 08-18-2014, 01:59 PM Thread Starter
jeffvader's Avatar
I know the lube discussion seems to ignite a war. This is my first bike and I'm in information gathering mode; building out tools, getting best practices down, etc.
I've found the search bar to be difficult to find what I need sometimes. I suppose I need to just keep at it.
You're Mr. Stevens?
post #4 of 24 Old 08-18-2014, 02:14 PM
zekester63's Avatar
Searching in Google is easier than within forums. Just put something like this into Google: site:stromtrooper.com chain lube
post #5 of 24 Old 08-18-2014, 02:22 PM Thread Starter
jeffvader's Avatar
That worked!
Thanks for the tip.
You're Mr. Stevens?
post #6 of 24 Old 08-18-2014, 04:42 PM
Webbikeworld.com has good reviews on chain lube. Ask at your favorite shop for the lube that doesn't make a big mess. Little or no cleaning is needed. Just a wipe with a dry rag or lightly moistened with any handy solvent so OK. (Dampening the rag with paint thinner or anything else is OK, submerging the chain in a strong solvent is not OK.)
You adjusted it for the correct slackness, right? A bit too loose is better than too tight. With the bike on the side stand, center of the lower run of the chain, lift & lower lightly with one finger. An inch of lift is good. 1-1/8" is better.
post #7 of 24 Old 08-19-2014, 11:36 AM
I've been using gear oil, only because i have tons of it in my shed from left over projects. 9400 miles now and the chain and sprockets look really nice. Thought I'd see more wear by now, but I lube at least once a week and at least every tank of gas, so fairly often.
The big downside to this is this stuff is so messy! There really is no way I can figure out to apply enought of it and not have it sling everywhere. Do I recomment it? Maybe as a last resort... but overall, no... I just had a ton of it to get rid of so felt like I had to use it up.
Can't wait till I run out and can switch to a motul or chain wax. It'll cost money, but should be much cleaner.
'12 DL650 ADV
'07 Victory Hammer
'06 Suzuki M50 (Traded)
MariusD is offline
post #8 of 24 Old 08-19-2014, 12:23 PM
O-ring chain lube... DuPont's version is like 4 bucks at Walmart.
DL650 K6
*Stock*
"...there won't be any money. But when you die, on your death bed, you will receive total consciousness. So I got that going for me... which is nice."
FiSKars22 is offline
post #9 of 24 Old 08-19-2014, 09:30 PM
I am using gear oil and bar oil 50/50. I am having a better experience with this than any spray I've used and it is way less messy. Almost no fling. The trick is the application; I pour a few drops on a little envelope sealing sponge and run the chain past it. It's easy to see when the chain is wet enough. No over spray and little to no fling. Takes me about a minute. The chain stays cleaner and cleans easier. I'll only use sprays now on overnight trips.
06 V-Strom DL650
John V Strom, Jr. is offline
post #10 of 24 Old 08-19-2014, 10:00 PM
Wrencher86's Avatar
I don't have a schedule for chain lubing. Basically just when I remember and am able to do it. At home I don't clean the chain. Just spray on some liquid wrench chain lube (it's better than nothing, I guess). If I'm at work and feel like taking the time I'll put the bike on the paddock stand (Center-stand is on my wish list) and use silicone spray and a toothbrush to clean the chain. Then whatever gear oil I might have laying around. I wipe of the excess with a rag and I'm good.
The gear lube seems to fling a lot and both methods make a mess wherever I'm working. Biggest thing about the gear lube fling is that it gets on the rear tire, which makes me a wee bit paranoid about aggressive left turns.
Basically, I think, anything is better than nothing and nothing really isn't that bad either. As long as you're not in excessively dusty/wet conditions I think an unmaintained chain still lasts quite awhile.
Wrencher86 is offline
