Ride On saved me & I didn't even know it - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 08-17-2014, 12:08 AM Thread Starter
cpr4life's Avatar
When I picked up my Vee today my mechanic showed me the rear tire he had removed. There were two spots where my tire had been punctured & the ride on did exactly what it's supposed to do. It filled in those punctures & I didn't lose a bit of air pressure!
Well worth the $10 per tire in my opinion!
2007 Honda ST1300
2007 Suzuki DL1000
2003 Suzuki DL1000 (sold)
2000 Yamaha Road Star 1600 (sold)
2004 Moto Guzzi Breva 750IE (sold)
2006 Kawasaki Vulcan 1500 Classic (sold)
2001 Suzuki Volusia CT50 (traded)
1986 Honda V65 Magna (sold)
1972 Honda CB350 (rode it 'till it dropped)
cpr4life is offline
post #2 of 20 Old 08-17-2014, 01:53 AM
mjcujo's Avatar
That's good info right there. I used Ride On in my last two Vees. The only flat I ever had, the Ride On failed. When I tried to plug the tire on the side of the road (mushroom plugs and gummies), I discovered the flat was caused by a one-inch gash. I couldn't stuff enough plugs in there to hold air. Not really a fair test for the Ride On. I think I'll give it another go.
Don't look back - you're not going that way.
mjcujo is offline
post #3 of 20 Old 08-17-2014, 03:18 AM
mattski1's Avatar
I currently use Ride On and think it's been successful for me. I picked up a screw right in the middle of my rear tire and as the tires were practically new (and given the location of the plug), I decided I was going to continue to ride the tire. I normally have zero issues with plugs, but this time I had a very slight leak. I got tired to airing up every couple of weeks, so I decided to give Ride-On a try. I now find that even though I check pressure pretty regularly, I only need to add a bit of air every 3-4 months. I've never experienced tire pressure that was so stable.
Will Ride On protect me when I catch the next screw? I don't know, but I will say that I'm happy so far.
2012 DL650A Adv.
mattski1 is offline
post #4 of 20 Old 08-17-2014, 04:40 AM
chrisbre's Avatar
Great to know - thanks
chrisbre is offline
post #5 of 20 Old 08-17-2014, 05:17 AM
Nox
Nox's Avatar
Is there any affect to the balance of the wheel using ride-on?
Seems like seriously good stuff. Wander if I will find it locally available...
Nox is offline
post #6 of 20 Old 08-17-2014, 09:22 AM Thread Starter
cpr4life's Avatar
Yes there is an effect on the tire balance...you can kiss the wheel weights goodbye as Ride On will continuously balance your tires!
2007 Honda ST1300
2007 Suzuki DL1000
cpr4life is offline
post #7 of 20 Old 08-17-2014, 09:30 AM
JohnnyReb's Avatar
What kind of mess is there to clean up during tire changes?
2013 DL650
You are never lost,
just temporarily misplaced.
JohnnyReb is offline
post #8 of 20 Old 08-17-2014, 09:41 AM Thread Starter
cpr4life's Avatar
Didn't look messy at all to me.
2007 Honda ST1300
2007 Suzuki DL1000
cpr4life is offline
post #9 of 20 Old 08-17-2014, 11:27 AM
There is none. It isn't like Slime at all. Ride-On gels and skins over. It stays on the inside of the tire opposite the tread. It won't seal a puncture toward the side of a tire but a tire punctured far off center needs to be replaced anyhow.
post #10 of 20 Old 08-17-2014, 12:20 PM
portabill's Avatar
Hardly any mess, no odor, might even taste good! Kind of looks like Poi....nah, it won't taste very good
2006 WeeStrom
2007 KTM 450 EXC
portabill is offline
