ProTaper Handlebars - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-05-2014, 03:00 PM Thread Starter
bobfrey101's Avatar
ProTaper Handlebars
It appears I have tweaked my handlebars...
Has anyone here installed protaper bars on there vee? If so what size/style and how do you like them compared to stock?
bobfrey101 is offline
post #2 of 12 Old 08-05-2014, 05:08 PM
Have the Pro-Taper hi atv's. Tried the mid atv's 1st and were too staright and too low. Get the S/E's (7/8") and they bolt right up to the stock mounts.
hodgkins is offline
post #3 of 12 Old 08-05-2014, 05:32 PM
Stalky Tracker's Avatar
Pro Taper Seven Eights (SE) ATV High bend here too, but I am on a Wee.
I like them. Much less sweep than stock.
There are a couple of other manufacturers with a similar spec'd bar; Tusk and MSR, I think. No experience, so someone else will need to chime in.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 12 Old 08-05-2014, 08:04 PM
catamount's Avatar
ProTaper SE ATV High here also. Since I have had PT SE bars on my KLR for over eight years I would be surprised if you didn't like them. They are super tough and the sweep is just right for me. I just put the same bars on my Wee. Here's a little bonus: I get less vibration through the PTs than I did with the stock bars. On both bikes. Win/win.
catamount is offline
post #5 of 12 Old 08-05-2014, 09:29 PM
jdad's Avatar
I also have the Pro Taper ATV hi bars but they are the fat bars with Pro Taper adapters. They are tough as nails. I had Pro Taper CR Hi bars when I flipped the bike and they didn't budge.
jdad is offline
post #6 of 12 Old 08-06-2014, 12:45 PM Thread Starter
bobfrey101's Avatar
Seems the 7/8 all have the cross bar, are you guys taking that off or running the cross bar?
post #7 of 12 Old 08-06-2014, 01:12 PM Thread Starter
bobfrey101's Avatar
How do those work with the oem hand guards and everything else that mounts on the bars.
post #8 of 12 Old 08-06-2014, 02:28 PM
catamount's Avatar
I'm using the crossbar and would recommend it for strength. I'm using the OEM guards and bar ends. I had to get some 1/4" ID fuel hose and some 6mm nuts to make the bar ends work with the ProTaper bars which have a smaller ID than the stock steel bars. There are several threads here on how to do it.
2008 DL650
2001 KLR650
post #9 of 12 Old 08-08-2014, 09:55 PM
+1.
I am running the cross bar, saw no reason to remove. I have had the oem bar ends, with the mentioned fuel line mod, on both sides. I now right the left oem bar end and a Kaoko cruise control on the right. No hand guards. All the other controls mounted and work fine. The controls do have a nub that needs to be filed or ground down, it is plastic and files down easily. Some drill their bars for the nub but to me that limits your ability to adjust them forward or backward as needed.
1974 Suzuki TM-250
1965 Suzuki 80
post #10 of 12 Old 08-09-2014, 11:01 AM
Brockie's Avatar
I have the ProTaper SE ATV Mid bars, which are pretty close to the same height as the stock steel bars. The High bars must be higher than stock, if that is what you want. I left the cross bar on, and the bar ends have several markings so that you can easily trim the overall width if you want. Untrimmed they are wider than OEM and do not bend back as much, resulting in a longer, wider reach to the bars.
Unlike the stock bars, I can feel them flexing while riding over the stutter bumps that you find on hard dirt roads.
Brockie is offline
