DL1000 rear shock on DL650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-04-2014, 04:57 PM Thread Starter
crosscountry's Avatar
The rear shock on my DL650 doesn't cut the mustard anymore. I refilled the preload, and that made a huge difference, but loaded up the rear tire hits the fender, even without a passenger. Add a second person and it's pretty frequent.
I was wondering if the DL1000 rear shock was stiffer than the one for the DL650 and if they are swappable?
Any other suggestions for stiffening up the rear shock?
Thanks.
All Bikes _ / _ The Wee
crosscountry is offline
post #2 of 12 Old 08-04-2014, 05:07 PM
jokermtb's Avatar
Don't order that 4th cheeseburger, Randy!
jokermtb is offline
post #3 of 12 Old 08-04-2014, 06:11 PM
Yes it fits , yes it's a bigger shock.
Lord , if I have to look like a Power Ranger , can it at least be Amy Jo Johnson?
Black Rhino is offline
post #4 of 12 Old 08-04-2014, 11:18 PM
It fits, I have one on my 650. It does feel like it "dampens" better.
But I don't think it will have a stiff enough spring for you.
2007 DL 650 with assorted upgrades
Solo is offline
post #5 of 12 Old 08-04-2014, 11:41 PM
Get a better shock or have yours rebuilt by someone like Racetech and set up to your weight.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #6 of 12 Old 08-05-2014, 01:14 AM
Agree with aftermarket option, a band aid is a band aid.
post #7 of 12 Old 08-05-2014, 11:53 AM Thread Starter
I'm 5'8" and weigh 160 lbs wet. My gear weighs less than 100 lbs all told. I find it hard to believe that a VStrom should bottom out at that low weight.
post #8 of 12 Old 08-05-2014, 11:53 AM Thread Starter
why is a beefier spring a band aid? If the DL1000 spring really is stiffer, isn't it an upgrade rather than a band aid?
post #9 of 12 Old 08-05-2014, 01:53 PM
To answer your question
I wouldn't call a beefier spring a "band-aid". If you can't get the correct sag & sack, I'd call it an improvement. However...
A quality aftermarket shock is a major improvement over stock. If you haven't experienced the difference you may not get it. Sometimes "seat of the pants" is the best way to understand this.
The best thing to do would be to understand how to get the correct ride height & sag. There's a lot of info on the web about this. We don't know for sure if your spring is correct with out performing these measurements.
Solo is offline
post #10 of 12 Old 08-05-2014, 02:13 PM
gryphon51's Avatar
Have you lowered the bike? I cannot fathom how the tire hits the fender, even my Darkside won't do that with 2 people and full camping gear..
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
