mixing coolant - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-04-2014, 03:32 PM Thread Starter
mixing coolant
was just reading a post on an a rider with a coolant leak due to different coolants being mixed. I thought all that stuff about different colors and types of coolants was over and just about everything mixed with every thing else. obviously I am wrong again (I am used to it). I added some to my bike on a recent road trip that said for GM and most Asian vehicles as I was not near a dealer. Hope I didn't do any damage. maybe some of the more knowledgeable folks can reassure me.
icnxpln is offline
post #2 of 6 Old 08-05-2014, 12:39 AM Thread Starter
anyone know this?
icnxpln is offline
post #3 of 6 Old 08-05-2014, 02:50 AM
No is the short answer. (for me, anyhow) The coolant I used said on the label that it could be mixed or is compatible with all other coolants. I took it at its word and have had no trouble so far, which is around 10,000 miles.
bobbyvstrom is offline
post #4 of 6 Old 08-05-2014, 04:58 AM
Mine gets drained rather than just topped up, but I'll admit I've never considered flushing the last drops out with water.
Also no problems - so far.
Bet someone put concentrate in the bike. Thought it was premixed and forgot to dilute it, that's about the only way that'd happen.
Pete
PeteW is offline
post #5 of 6 Old 08-05-2014, 01:10 PM
I don't think this was the cause of his leak.
It'll mix, but isn't optimal and may cause long term damage (Dex-cool uses plasticisers that are not good for certain gaskets, for example).
Our engines and radiators seem to live well with everything. In your case, how about doing a drain and refill including the expansion tank. I use Zerex Asian Engine antifreeze. Others use a universal antifreeze. Both are good for 5 years. Or a motorcycle specialty antifreeze is good, but check the label for the life of the corrosion inhibitors (usually 2 years or 5 years depending on the formulation).
post #6 of 6 Old 08-05-2014, 03:49 PM
Add corrosion/ pump lubricant instead
richw is offline
