Socket in the Staintune pipe - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 07-29-2014, 10:47 AM Thread Starter
Well last night I was out in the garage and happen to walk up on my 21 month old grandson as he was depositing a deep well socket into the end of my exhaust. Sure enough it slid right down into the bowels of the muffler. I started it up and didn't notice any ill effects or rattles. I'm hoping to I can remove the muffler and shake it out. Any ideas ??
HOOVEY is offline
post #2 of 10 Old 07-29-2014, 10:54 AM
If it's a "straight-through" pipe like my 2-Bros, then try a magnetic wand to see if you can retrieve the errant socket. You can get one an any hardware or parts store. Usually collapsible. Very handy little device. Bobby
bobbyvstrom is offline
post #3 of 10 Old 07-29-2014, 12:57 PM
Mastery's Avatar
Hmmm...tough one. Keep pushing other stuff in there and see if you can push it out the fuel tank opening? :mrgreen:
Go to your local big box hardware store, and get a flexible magnetic wand. OR, remove the muffler and do the shake/shake with it.
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #4 of 10 Old 07-30-2014, 12:22 PM
Socket in the exhaust...
I have a magnet on a telescoping rod that I use occasionally. The magnet is not very strong. It's good for small bolts, washers, etc, but may not be able to hold a full-sized socket. It extends 21". There is also a spring-loaded "grabber" available, which I have. There is a plunger on one end that works like a hypodermic. The other end has four springy "fingers" that open and close as the plunger is pushed and released. It is flexible and can be weaved into an exhaust. It has a length of about 22". You could take a dowell rod or some other length of material and afix a wad of sticky tape, like duct tape, on the end. Weave it down in there and maybe the socket will stick to it. The duct tape MUST be stapled, nailed, etc, to the rod or it will stick in the exhaust when the rod is pulled out. You could use a strong magnet on the outside of the exhaust to to slide the socket closer to the opening. These are all things I have used in the past to get stuff out of small spaces. Good luck.
Ahnold Stromzenegger is offline
post #5 of 10 Old 07-30-2014, 02:53 PM
Bugzy's Avatar
I would probably start with an inspection camera to see how far in it went. The magnet idea would probably work too, you could even attach the camera to the magnet so you could see where it goes.
Bugzy is offline
post #6 of 10 Old 07-30-2014, 07:58 PM
randyo's Avatar
just do a vertical wheelie
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #7 of 10 Old 07-30-2014, 08:21 PM
Dark Angel's Avatar
If your Staintune is like mine it's a straight through pipe and you should be able to split the system down near the right foot peg and drop the socket out. If it's identical to mine there's an O2 sensor that might get in the way.
Dark Angel is offline
post #8 of 10 Old 07-30-2014, 11:29 PM Thread Starter
Just like Dark Angel suggested I removed the muffler by unhooking it near the foot peg and with a little shake it came right out.
HOOVEY is offline
post #9 of 10 Old 07-31-2014, 12:08 AM
Send the grandson in after it?
meick is offline
post #10 of 10 Old 07-31-2014, 10:23 AM
Phinhead's Avatar
pro·phy·lac·tic
ˌprōfəˈlaktik/Submit
adjective
1.
intended to prevent disease.
"prophylactic measures"
synonyms: preventive, preventative, precautionary, protective, inhibitory More
Phinhead is offline
