D.I.D. Chain & Sprocket Kits - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 07-27-2014, 03:10 AM Thread Starter
I just purchased a 2006 DL650 and want to replace the chain and sprockets. How do the D.I.D. kits compare to other kits? D.I.D. claims that the x-ring chains last longer than other type of o-ring chains.
Also, do they use high quality sprockets?
I noticed that Amazon.com offers these kits for about $30 less than some of the bike-parts websites.
DawgHunter is offline
post #2 of 16 Old 07-27-2014, 03:17 AM
Xtracrispy's Avatar
DID has a good reputation. I have run them on and off road and can't say I've had a problem, but I'm super lazy when it comes to chain care so I don't get near the time/miles out of my chains as some do! I'll probably replace my DID O-ring with a DID X-ring when that time comes.
Someone else with more experience may have a different viewpoint, though.
Street: 2006 Suzuki "Wee"-Strom.
Dirt: 2003 Suzuki LTZ-400.
2004 Honda CRF230.
2003 Ducati Monster 620Sie (Sold)
2001 Honda XR650R street legal(Sold)
2006 Ninja 250 (Sold)
2001 KTM 520MXC (Sold).
+ more off road bikes sold.
Xtracrispy is offline
post #3 of 16 Old 07-27-2014, 09:13 AM
Motor7's Avatar
I have this here ready to install:
SUZUKI DL650 V-STROM '04/13 JT X-RING CHAIN AND SPROCKET KIT *OEM Premium
It's JT sprockets and I suspect a DID chain. I have had a DID x-ring chain on my DRZ for 3K miles and I like it.
15 DL650XT
Motor7 is offline
post #4 of 16 Old 07-27-2014, 10:27 AM
I like DID. They seem to be tough. If your sprockets are steel, you should be fine. I think I got mine from The Sprocket Center. I went with Superlite steel sprockets. Good so far.
06 V-Strom DL650
John V Strom, Jr. is offline
post #5 of 16 Old 07-27-2014, 12:26 PM
Banned
EK chains are just as good as DID at about 1/2 the cost. JT sprockets are good but, not as good as OEM sprockets.
V-Strom (Suzuki DL1000) | Fuelly
JRWalker is offline
post #6 of 16 Old 07-27-2014, 12:39 PM
randyo's Avatar
everybody's experience is different, riding style, personal weight cargo, road conditions etc.
my experience is that I wear my front sprocket long before I see any wear on the chain or rear sprocket
as someone already said, oem sprockets seem to last the longest, especially the front
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #7 of 16 Old 07-27-2014, 08:05 PM
DID has endless chain for the vstroms.Check to see what the correct number of links is for your year and model. No cutting and riveting is the up side, but the swing arm pivot nut/bolt have to be removed. A special socket is required. However instructions for a home brew socket can be found online, this forum I believe.Not a big job making the tool.If you go the rivet rout a spare,or two, master link[s] maybe a good thing depending on how demanding your riveting standards and skills are.A proper tool should be used for flaring the rivets to the DID spec. Either way it is very doable for most people with care and patience.Cheers Doug
Hfxoldvolks is offline
post #8 of 16 Old 07-27-2014, 11:15 PM Thread Starter
Thanks for all the replies!
Thanks for the replies everyone; I appreciate the useful information.
Hfxoldvolks, why does the swingarm pivot nut/bolt have to be removed? Is that required in order to access the cover over the front sprocket? Thanks for the heads-up, I will try to get one of the special sockets.
post #9 of 16 Old 07-28-2014, 12:29 AM
The swing arm pivot shaft only has to be removed to install an endless chain, which almost nobody does. Cut the old chain off, rivet the new chain on.
The OE chain is DID. Replacement DID VX or ZVX-M chains will do a great job, as will top chains from, EK, RK, Renthal, JT, and others. On a 1000, 530 width chain and sprockets gives longer life.
post #10 of 16 Old 07-28-2014, 12:30 AM
Xtracrispy's Avatar
The swingarm would only need to be pulled for using and endless chain. Since there are no ends you can't "weave" it up through the frame around the countershaft sprocket. A normal chain with a master link you don't need to remove the swingarm. Some people don't like having master links on their chains so theyprefrer endless.
2004 Honda CRF230.
