Height issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 07-26-2014, 01:02 AM Thread Starter
Height issue
Hi, im about to buy the 2014 650 abs v strom, but im getting second thoughts since im 5/7 and im on my toes when im standing. Ill post a pic to get sugestions. I dont want to fall in a standing position, in a rainy day or manouveri g between cars in the traffic.
Soporama is offline
post #2 of 16 Old 07-26-2014, 01:16 AM
H8-3Putts's Avatar
Thicker soles on your boots help, taking the rubber cushions off bottom of seat drops it some (or cutting them in half), lowering links should get it down as far as you need it.
H8-3Putts is offline
post #3 of 16 Old 07-26-2014, 01:28 AM Thread Starter
Thanks! Im gonna buy it tomorrow! Do you know if lowering the bike affect its performance in any way!
Soporama is offline
post #4 of 16 Old 07-26-2014, 01:30 AM
Seat height of new 650
Yes, they're tall, like all adventure bikes. Removing the seat rubbers is a good idea, dropping the forks through the triples up to an inch helps and lowering links in the rear. Less preload on forks and rear helps too when you are sitting on it. You do get used to the height. Like not stopping on sloped road shoulders or dips in the pavement like driveway entrances. The tradeoff is a comfy ride and moderate off-road capability. It's worth it
bobbyvstrom is offline
post #5 of 16 Old 07-26-2014, 03:51 AM
I'd suggest removing the bumpers and replacing with stick on furniture feet.
That means it's easy to restore to stock (if you decide to sell it) and the rubber furniture feet will protect the seat plastic. (Stop it wearing against the frame).
Pete
PeteW is online now
post #6 of 16 Old 07-26-2014, 06:49 AM
I am 5 7 with a Vee
Scootch forward rock your hip
Learn the high kick mounting
richw is offline
post #7 of 16 Old 07-26-2014, 07:26 AM
RichardD is offline
post #8 of 16 Old 07-26-2014, 11:29 PM
middleage crazy's Avatar
I'm 5'9" and lowered my bike using the Kouba Links 3/4" (lowering the forks 3/4" also) and I've noticed no difference in handling before or after the links. With the stock seat I could get both feet flat on the ground but with my Terry Adcox seat I get the balls of both feet down. Here's the web address for the Kouba Links for the V-Strom.
Kouba Link
Hope this helps.
middleage crazy is offline
post #9 of 16 Old 07-27-2014, 01:04 AM
ventureman's Avatar
I'm the same height as youself. Always more of a challenge while in running shoes. Haven't lowered anything on mine and don't plan too. You learn to ride and watch for obstacles that may present a problem, such as not pulling to the crest of the road when stopping. It's a awesome bike, don't let the seat height scare you away, many ways to fix or adjust. Good luck.
"Duct tape can't fix stupid, but it can muffle the sound"
[SIZE="2"][I]2012 DL 650A "Recon Rex"
2007 KTM 990 Adventure
2003 Honda 750 Nighthawk
2000 Yamahie XT225[/I][/SIZE]
ventureman is offline
post #10 of 16 Old 07-27-2014, 01:07 AM
Dirt bike method
Most dirt bikes are much higher than the DL. What works is to slide forward and off to one side, so that you get one foot flat on the ground when stopping. ( hooking one knee on the edge of the seat)
Down shift to first gear before you stop.
When you are taking off , let out the clutch etc. and as you pull away slide back into the middle of the seat.
xrman is offline
