Liquid gasket sealant - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 07-24-2014, 09:09 PM Thread Starter
janiceclanfield's Avatar
I will be replacing the stator on a 2003 Honda Shadow, and the manual calls for a liquid gasket sealant instead of a rubber gasket.
Can anyone recommend brand names of this stuff so I know what to buy? I'm in Canada, but Canadian Tire sells lotsa stuff from the states, so I can probably get the same brands as you guys south of the border.
Yes, I know. I'll put the bong away until -after- the stator is installed...
janiceclanfield is offline
post #2 of 17 Old 07-24-2014, 09:25 PM
millwright98's Avatar
Janice, Permatex Black gasket sealant...on the shelf at Canadian Tire ... follow the instructions on the package and you shouldn't have any issues Craig
2002 DL1000 K2
millwright98 is offline
post #3 of 17 Old 07-24-2014, 09:34 PM
Liquid Gasket...
I have used ThreeBond Silicone Liquid Gasket 1211, Part Number TB-1211. It's expensive stuff at $25.00 USD for a 3.5 oz tube, but it's the good stuff. Has worked great on our bikes.
Ahnold Stromzenegger is offline
post #4 of 17 Old 07-24-2014, 09:46 PM
fortp's Avatar
What Millwright said, or this:
Kleen-Flo | Products - Gasket Black
fortp is offline
post #5 of 17 Old 07-24-2014, 09:52 PM
Whatever you use, be very careful and don't let big gobs of it get on the inside perimeter of the case or cover. You don't want pieces of the solidified sealant breaking loose and getting into your engine, where it can clog oil passages, and get between gear teeth, etc.
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
post #6 of 17 Old 07-24-2014, 10:17 PM
supernewf71's Avatar
suzuki bond used to be wicked. worked on lots of stuff. not even sure they still make it.
Dave
2004 vstrom 650 blue
Past bikes
1982 yamaha virago 750
1982 Honda nighthawk 750
supernewf71 is offline
post #7 of 17 Old 07-24-2014, 10:45 PM Thread Starter
And the winner is:
Just because I'm lazy and cheap. There's a Canuck Buck right down the street.
Thanks everyone.
post #8 of 17 Old 07-25-2014, 06:20 PM
Amazon.com: Three Bond Liquid Gasket 1194 TB1194: Automotive
Do NOT trust silicone in continuous hot oil applications
richw is offline
post #9 of 17 Old 07-26-2014, 10:22 AM Thread Starter
The stator side of the case is not oil filled. There may be a teensy bit of oil that has seeped past the crankshaft seal, but that's about it. So I'm not too worried about lots of hot oil.
The clutch side would be an entirely different matter, as it's full of hot oil all the time.
Thanks for the feedback everyone, and have a happy bong-filled day. :beatnik:
post #10 of 17 Old 07-26-2014, 12:10 PM
Janice, just to beat it into you again, just a film on both surfaces is your friend. Too much, and NOT your friend. Even if it is not part of the crankcase you don't want globs of that stuff floating around. A film will seal just as good as a bead in this case.
realshelby is offline
