Where is the end to your heated gear battery harness? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 29 Old 07-24-2014, 05:34 PM Thread Starter
Mastery's Avatar
Curious where you all are running your heated gear connection from the battery. I brought it out by the rear passenger footpeg, but of course it's not close enough for my jacket wire to reach it. Thought about bringing it up between the seat and the gas tank in front...but not sure I want it flopping around while riding and not using it, and don't see a place to put it without removing the seat. In the winter months, I don't want the wind blowing it around against the tank when in a store or whatever.
Would like to leave it on the bike because I ride all year around. For some reason, the obvious place to place the end where I can connect to it is alluding me.
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #2 of 29 Old 07-24-2014, 05:41 PM
Sagebrush's Avatar
Left side of the seat's bottom all the way forward, tuck it under the seat when not in use leaving the connector showing. I keep the lead as short as possible.
Sagebrush is offline
post #3 of 29 Old 07-24-2014, 05:42 PM
My harness gets stored under the seat inside the left side cover. When it needs to be used, it comes out between the seat and the plastic frame cover on the left side, just behind the tank. I put a depression in the plastic with a soldering iron to create space and provide a wide, flat area for the wiring harness to sit on.
post #4 of 29 Old 07-24-2014, 05:45 PM
BabaAus's Avatar
Mine just sticks out from under the seat at the tank end during cold weather. The rest of the year it hides under the seat.
BabaAus is offline
post #5 of 29 Old 07-24-2014, 05:47 PM
tmcgee's Avatar
Same for me. I also use dual lock to keep the controller on the tank.
tmcgee is offline
post #6 of 29 Old 07-24-2014, 06:04 PM
I purchased a "Plug" (think "outlet") that one mounts like a dash power outlet.......made a bracket out of aluminum and mounted the plug on it. It is located forward below the tank using one of the SW-Motech Crash Bar Bolts. I always had a problem trying to plug the male end of the vest's wiring into the female receiver using one hand when the female part was simply dangling outside the bodywork. Now, it's easy (one handed).
www.easternvstromrally.com
mark444 is online now
post #7 of 29 Old 07-24-2014, 06:28 PM
bmwlarry's Avatar
It is long and tucked under my seat except when I need it!
2013 Yamaha WR250R
2009 V-Strom 650DL-ABS
2015 Can Am Spyder RTS LTD SE6
2011 Can Am Spyder RT Limited - Sold
2010 Aspen Sentry Camping Trailer
2003 BMW K1200LT - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 Nighthawk - Sold
1997 Honda 750 Nighthawk - Sold
bmwlarry is offline
post #8 of 29 Old 07-24-2014, 06:33 PM
Inside my tank bag. I have the powerlet tank bag electric kit in my givi tanklock tank bag. Power runs through that. There is a splitter inside, 1 a cigarette lighter plug, the other a DC power plug, that then plugs into a 12v/USB box I built. It has 4 USB ports, and 2 12v power outlets, of which 1 is switched, and runs a 6" 5 or 6 LED strip for lighting in tank bag, the other, not switched, runs heat troller.
Wow, that was a lot to explain! Don't know why I can't post pictures, but I have posted them before. I do have a thread on here of one, that one is version 1, I've since built the one I described above, version 2.0. The new one doesn't have a cigarette lighter socket, but has the switched 12v outlet, but I have the splitter so I don't need it, plus with Chinese USB module, only 2 of the 4 USB ports work...
danhikeski is offline
post #9 of 29 Old 07-24-2014, 06:38 PM
Banned
The lead comes out from under the seat at the front of the saddle.
The controller is duct-taped to my tank-bag so it is easy to reach the controls.
Rashnak is offline
post #10 of 29 Old 07-24-2014, 06:55 PM
donmac's Avatar
On the 12+ it fits nicely in the side cover.
2012 Vstrom 650 Adventure
donmac is offline
