Tac outta Black - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-19-2014, 11:10 AM Thread Starter
Tac outta Black
So what happens when you get her into the RED, just for a sec - or longer? And does the first gen Wee have a limiter?
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #2 of 14 Old 05-19-2014, 11:14 AM
I've wondered the same thing.
I saw my other bike flash red when getting on the freeway. Alwas wondered about the Wee. My 1100RT was fun to bounce off the rev limiter.
post #3 of 14 Old 05-20-2014, 05:29 PM
Bugzy's Avatar
This thread sounds like "Here, hold my beer and watch this" kind of thing...
Let someone else try it...
Bugzy is offline
post #4 of 14 Old 05-20-2014, 05:42 PM Thread Starter
r u calling me stoopid :iamwithstupid:
'08 Yellow DL650
BumbleV is offline
post #5 of 14 Old 05-20-2014, 05:52 PM
Bugzy's Avatar
Did you try it and your engine exploded? Was there any fire?
I think i'm just too old to try stuff like this anymore. When i was 20 i would have immediately run outside to test it.
Bugzy is offline
post #6 of 14 Old 05-20-2014, 05:54 PM Thread Starter
I didn't try it on purpose - no fire
'08 Yellow DL650
BumbleV is offline
post #7 of 14 Old 05-20-2014, 05:59 PM
hunt1moore's Avatar
It's toast!
It's a "has-been" now! Used-up!
Time to go get a new one.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #8 of 14 Old 05-20-2014, 06:18 PM
randyo's Avatar
fwiw, I accidentally downshifted in to 1st gear @ 70mph with my SV650, not once, but twice, brain fart
first time I probably had 50k on the bike, I had recently switched to GP shift
I decide to sprint quickly up to a ton for the hell of it, solo ride, no traffic, as I pull away from my stop, I bring it up to redline in 1st, than push down on the shifter into second, click, bring it to redline in 2nd, here is where I had my brain fart, I put my toe under the shifer and click it back up into 1st then release the clutch, instant rear tire chatter, tachometer pointing due east (estimate 14,000rpm) but I quickly realize what has happened and pulled the clutch, when I got speeds and revs matched, I continued on, no ill effects, it was probably only at 14k a split second
second time, about 90k on my SV, I was riding with my son's (one on VFR, other on Yamaha Maxim) I was bringing up rear as we went thru a slowdown area, I was in 2nd gear, as we passed the slowdown area and got to open road, we accelerated quickly, again, I bring it up to redline in 2nd, and instead of pushing down to 3rd, I click back up into 1st, this time I was a real space cadet, I was doing everything I could to keep the bike shiny side up, why was a skidding all over the place, probably only went on for 2-3 seconds, but at the time it seemed forever, the tach was pointing due east
maybe that is what caused my valve guides to be worn at 135k
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 14 Old 05-20-2014, 06:20 PM
I don't know about the first generation but I was trying to outrun a Harley away from a stop sign on my 2012 650 and hit the rev limiter. His bike was so loud I couldn't hear mine at all. I was slamming through the gears and then it felt like I turned the ignition off. It took a second for me to realize what happened then I shifted up again.
I stayed in front of him the whole time
2012 V-Strom 650 Adventure, 2008 YZ250 2 Stroke Woods Weapon
crash_bandicoot is offline
post #10 of 14 Old 05-20-2014, 06:59 PM
Even the first Wee, 2004, has an over-rev limiter. The ECM cuts power to the injectors when the limit is exceeded.
