Let's Talk Wobbles - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-13-2014, 12:20 PM Thread Starter
Let's Talk Wobbles
Everyone talks about the decel wobble. WHEN LOADED, my bike wobbles at around 35mph whether I am accelerating, decelerating or going steady. Stock suspension. Forks raised in tubes 13mm. Lowering links, but rear is at or near stock height, but this does not seem to matter as wobble is present at all adjustments of lowering links. NO WOBBLE when not loaded.
What say you?
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is online now
post #2 of 17 Old 05-13-2014, 01:23 PM
What tires are you running. The Shinko/Full Bore I use have a "walk" at low speed , but the Factory Trailwings were all over the place. Glad those are gone.
Lord , if I have to look like a Power Ranger , can it at least be Amy Jo Johnson?
Black Rhino is offline
post #3 of 17 Old 05-13-2014, 01:34 PM
Need whole story
tires age mileage pressure you run
Mine only moves when there is a big load like camping
Steering head bearings stock are inadequate and need frequent adjustment
richw is offline
post #4 of 17 Old 05-13-2014, 01:42 PM
VSrider's Avatar
A new tire solved my wobble issue. The OEM Trailwing was cupped bad so I installed Pilot Road 3 and the wobble went away.
VSrider is offline
post #5 of 17 Old 05-13-2014, 02:01 PM Thread Starter
First noticed this fully loaded for 2 month trip, running brand new Anakee IIs. 10,000 miles on that trip and as far as I can remember the wobble was everpresent. Put brand new Anakee IIIs on before fully loading for 5 week trip. Wobble has been consistent for 8000 miles. I generally run 33 PSI in front and 38 - 41 PSI in rear. I purchased bike at 10k and have put 30k on it.
I can manage it, but wobble is noticeable even with two hands holding bars lightly. If I take hands off bars, it would eventually wreck. Wobbles only when loaded.
'08 Yellow DL650
post #6 of 17 Old 05-13-2014, 02:31 PM
If you lean forward does it go away or get better. Have not experienced it on the Wee yet, but my KLR would do it at speed when ever I used to put my feet on the rear pegs. Too much weight in the back lightens the front end and depending on the tire tread, could enduce a wobble. If that is the case you need to drop the front end or raise the preload in the back and see if it gets better.
2010 Wee-Strom 650A
2012 Moto Guzzi Stelvio NTX
2009 KLR 650 (sold...need a bigger garage)
canuck1969 is offline
post #7 of 17 Old 05-13-2014, 03:12 PM
if your bike is lowered at the front,and at the back, then it really shouldn't affect geometry. The fact that you say it happens when it's loaded, means that you may very well have too much stuff on it, or the fact that the front end is light. Weight bias.
does accelerating improve or worsen the situation. does compression braking improve or worsen the wobble?
In my experience, a wobble is fixed by more power. Throttle fixes everything
Greg the Pole is offline
post #8 of 17 Old 05-13-2014, 03:18 PM Thread Starter
Yes, should have mentioned I am probably 155 lbs. with all my gear on. Tank bag may add another 5 lbs. Wobble only seems to occur between 30 - 35 mph and when bike is loaded. Accelerating makes it go away - but then again my hands are on the bars. Does get worse as it decels with hands off bars. Don't know about compression braking because again hands are on bars.
'08 Yellow DL650
post #9 of 17 Old 05-13-2014, 03:25 PM
rubenz's Avatar
I had a bit of this issue when taking slow sweeping corners especially when not on the power. A discussion on this board said it may have been a number of things and it was focused down to the steering stem nut maybe being loose. However, I adjusted my pre-load nearly all the way positive for a camping trip that had me loaded heavy and it seems to have solved the problem. I think my fat ass just needed more pre-load on the rear suspension. Maybe this is the problem when you are loaded up?
2006 DL650
Growing farkle list: Aux LED's on SW Motech Light Bar, Bark Busters, OEM Touring Screen, Bestem LED Top Case, Charging Port, DL1000 Seat, Madstad Bracket w/MP Cycles Windscreen, Pat Walsh Design Radar Shelf, Neslon Rigg CL-855 Luggage, Givi Engine Guards, Sargent seat.
Iron Butt Association Member - Qualified with 1,118 mile Saddlesore
rubenz is offline
post #10 of 17 Old 05-13-2014, 03:30 PM
gryphon51's Avatar
Steering head bearings fixed this on mine....
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
