Removing tank graphic - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-11-2014, 11:08 AM Thread Starter
I don't care for the large zigzag on the tank graphic on late model V-stroms. Can it be removed with a heat gun or it is under a clear coat?
keithert is offline
post #2 of 17 Old 05-11-2014, 11:13 AM Thread Starter
Here is what I'm referring to.
keithert is offline
post #3 of 17 Old 05-11-2014, 11:22 AM
No clear coat covering. Heat is a good start to release the sticker. https://www.stromtrooper.com/maintena...-stickers.html
post #4 of 17 Old 05-11-2014, 05:48 PM
LordSmoke's Avatar
Easy peesy. Mine and the silver S came off without incident. The decals on the back panels came off, but left a raised pattern. The pattern was subtle, but I ended up buggering the paint trying to get it off. Better to have left it alone once the decals were off.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #5 of 17 Old 05-11-2014, 09:42 PM
That is a funny thread, the tyre pressure label is a Federal mandated label. As always someone is the know it all of everthing.
Tire Safety Information, Final Rule.
racenviper is offline
post #6 of 17 Old 05-11-2014, 09:57 PM
Location: North Augusta, South Carolina,USA.( C.S.R.A. )
Just heat that sucker up and peel it off then get some goo off to remove any tacky glue residue left behind.Now you can go to a graphics place that makes custom decals and design something real cool for it .I am having the Gold Flake S and the VStrom and the rear DL 1000 made for my red 2006 DL 1000 It looks like the gold flake used on the fire trucks its cool cant wait till he is done with them.
RICK
PSALM 31
REMEMBER YOUR SAFETY FIRST ALWAYS WEAR YOUR HELMET
My Current Motorcycles
2010 Honda VFR1200F Manual ABS Sport Touring
2008 Kawasaki VN2000J Vulcan 2000 Classic LT Big 2053 cc Cruiser
OUT DOOR SOUTH is offline
post #7 of 17 Old 05-11-2014, 11:02 PM Thread Starter
Thanks all for the tips. My 2005 has a nice understated graphic. But I don't care for the big graphics they put on the newer ones. And I may look at getting a newer Vstrom 1st gen rather than the Wee2 in the future.
keithert is offline
post #8 of 17 Old 05-11-2014, 11:10 PM
Nemisus's Avatar
Careful with the goo gone.. I just removed the decals on my 2012 Vee and used a spray version. This type left permanent runs on my plastics. Its happened fast too. The time it took to grab my towel after spraying was enough. Mere seconds really!
If you need to use it I'd spray it into your towel rather than directly on the fairing.
Fortunately its hard to see with the Nebula Black paint, but its there if you look.
2012 DL1000
Delkevic Carbon Fiber Exhaust, Corbin Cayon Dual Sport with Back Rest, Givi Crash Bars, SW-MOTECH Engine Guard, SuperBrace Fork Brace, Oxford Premium Heated Grips, Power Commander V, Updated ECU and Plugs, Pro Taper SE Raptor bar, DL1000 Adventure decals, Adventure Tech foot controls, Adventure Tech rear spacer, Adventure Tech Kick stand Foot, OEM Top case and Side bags, OEM Hand Guards. The farkles will continue....
Nemisus is offline
post #9 of 17 Old 05-11-2014, 11:46 PM
Vaseface's Avatar
I took my rear decals off my 04 650 after they had been on there 10 years. Heat first allowed me to get most of it off. Then I used Goof Off on the sticky bits - and promptly damaged the paint (it looks faded). Learn from my mistake and don't use Goof Off, particularly on the plastics.
Good luck.
Vaseface
Northern California
14 DL1000
Vaseface is offline
post #10 of 17 Old 05-12-2014, 01:04 AM
Excerpts from rule:
"This rule applies to all new and retreaded tires for use on vehicles manufactured after 1975 with a gross vehicle weight rating of 10,000 pounds or less and to all new vehicles with a gross vehicle weight rating of 10,000 pounds or less, except for motorcycles and low speed vehicles."
"This rule establishes that its labeling revisions apply, except where noted, to new pneumatic tires for use on motor vehicles with a GVWR of 10,000 pounds or less, manufactured after 1975, except for motorcycles and LSVs, and for new motor vehicles with a GVWR of 10,000 pounds or less."
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
