Bad fuel?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 23 Old 05-08-2014, 09:52 PM Thread Starter
Surplustravis's Avatar
Bad fuel??
Ok so I was down to 2 bars left on fuel gauge and everything was good no issues I filled up with 87 and rode back to work as I'm going up a hill just lugging it behind grandma I hear some spark knocking I've never ever heard before. Just wonder if you guys think I got some lously fuel today??
Surplustravis is offline
post #2 of 23 Old 05-08-2014, 10:17 PM
Define lugging. Your profile says you have a Wee. Were you under 3000rpm, under 2500?
post #3 of 23 Old 05-08-2014, 10:18 PM Thread Starter
6 gear 35 mph
post #4 of 23 Old 05-08-2014, 10:23 PM
Use 5th gear at 35mph and don't select 6th until 40mph on flat roads, 45mph on rolling hills. If your TPS and TBS settings are perfect, you can putt along at 2500rpm but it's on the ragged edge.
post #5 of 23 Old 05-09-2014, 12:35 AM
The rpm vs. gear choice depends on the load on the engine. That said, 65 mph is my minimum for 6th, and I'll probably be in 5th at 65. At 35 mph I'd be in 3rd, maybe 4th if running easy. And, yes, you may have gotten a tank of bad gas. Siphon it out and use it in a full tank in your car if you don't want to burn it in your bike. If the next tank still runs poorly due to this gas, try any gas system cleaner; use according to the label instructions.
post #6 of 23 Old 05-09-2014, 06:50 AM
Doctor It hurts when I do this
Well don't do that!
richw is offline
post #7 of 23 Old 05-09-2014, 07:33 AM
Mastery's Avatar
Originally Posted by Surplustravis View Post
6 gear 35 mph
I'm no expert on the mechanical side of motorcycles but have ridden them for decades. I usually don't touch 6th gear on any motorcycle until around 60 MPH, including those short-shifting Harley's.
At 35 MPH, stay in 4th...bet it doesn't lug then.
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #8 of 23 Old 05-09-2014, 07:42 AM
Banned
Arrow
yeah. How to Check Your Vehicle's Gas Mileage and Octane Requirements
JRWalker is offline
post #9 of 23 Old 05-09-2014, 09:08 AM
gryphon51's Avatar
6 gear 35 mph
looks like you have a defective user there...... :beatnik:
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
post #10 of 23 Old 05-09-2014, 10:21 AM
chicago's Avatar
Like others I only use 6th at 65mph and up. Bike likes to cruise around 6.5k and makes good power/torque in that area.
chicago is offline
