What would you do with this turn signal? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
View Poll Results: What would you do with this turn signal?
Replace with stock. 31 37.35%
Replace both with aftermarket. 25 30.12%
Epoxy inside and use with cracks. 13 15.66%
Retape it with better tape. 7 8.43%
Nothing. 6 7.23%
Remove all the turn signals because they are not cool. (The PO of my Vulcan did this) 1 1.20%
Voters: 83. You may not vote on this poll
post #1 of 45 Old 05-08-2014, 08:39 AM Thread Starter
I gently laid my bike down in the driveway while attempting to put it onto a swingarm stand and broke the right turn signal housing. The lens in split into two pieces. The body is in three. I was able to tape it together with packing tape enough to ride. It is functional. From the options in the poll what would you do with it?
keithert is offline
post #2 of 45 Old 05-08-2014, 08:56 AM Thread Starter
This K&S Technologies - 25-3215 looks to be a close match. It is for a GSXR-600.
keithert is offline
post #3 of 45 Old 05-08-2014, 09:18 AM
gryphon51's Avatar
even with the Givi crash bars the stock signals are vulnerable in any kind of scenario where the bike ends up lying down. After eating 2 stock ones learning this in the first year of my off road exploits, I bougt a set of semi flush mount ( less than 2" profile) aftermarkets for under 10 bucks and they have performed well ever sice
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
post #4 of 45 Old 05-08-2014, 09:30 AM
I replaced mine after the same problem in my garage except the left side. Ordered the stock replacement from ronayers.com. Looks good as new!
I ride for the pure fun of it!
2008 FZ1
STOC#7404
Farkles: Madstad Bracket, Adventuretech Fork Brace, Mirror Extenders, Lowering links. Power Commander V,
Garmin GPS on Strombone mount, Sargent Seat, Radar Detector, Oxford Heated Grips, Grip Puppies, Givi Monokey Top Box & Panniers, Center Stand, Givi Engine Guards.
Lanny is offline
post #5 of 45 Old 05-08-2014, 09:41 AM
Mastery's Avatar
Have a link to what you purchased?
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #6 of 45 Old 05-08-2014, 09:43 AM
which ones and where did you get them?
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #7 of 45 Old 05-08-2014, 09:55 AM
I replaced broken indicators with some 20 dollar Chinese aftermarket that would have a running light too is I weren't so lazy. What I got was slightly smaller but still had flexible stalks and work fine.
post #8 of 45 Old 05-08-2014, 11:11 AM
nwfirerider is offline
post #9 of 45 Old 05-08-2014, 11:13 AM
bmwlarry's Avatar
Here is what I use on my bike. I love them, they are bright and out of the way and a bit pricy!!
Touratech LED Mini Indicators
2013 Yamaha WR250R
2009 V-Strom 650DL-ABS
2015 Can Am Spyder RTS LTD SE6
2011 Can Am Spyder RT Limited - Sold
2010 Aspen Sentry Camping Trailer
2003 BMW K1200LT - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 Nighthawk - Sold
1997 Honda 750 Nighthawk - Sold
bmwlarry is offline
post #10 of 45 Old 05-08-2014, 11:35 AM Thread Starter
A local friend offered me a signal off this Bandit. I do like the looks and easy install of that Touratech setup.
keithert is offline
