Questions about fork braces - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-04-2014, 07:22 PM Thread Starter
I just put one on my Wee this spring and wished I had done it 4 years ago when I got it.
My questions are, do all motorcycle models benefit from a brace? If so, to a similar degree? Do some bikes come with them standard?
Just curious since it made such a difference to me.
Thanks
mikeg
K5 Wee (Blue)
mikeg is offline
post #2 of 6 Old 05-04-2014, 08:42 PM
Some bikes come with fork braces built into the fender mount. Bikes with so called upside down forks like the new Vee2 don't need them.
post #3 of 6 Old 05-04-2014, 08:45 PM
RLBrooks's Avatar
Ok, I'll bite. Why not?
Cheers... [B][I][COLOR="Red"][FONT="Comic Sans MS"]Russ[/FONT][/COLOR][/I][/B]
2012 DL650AL2 Adventure (Sold)
2013 TU250x
RLBrooks is offline
post #4 of 6 Old 05-04-2014, 08:50 PM
kiwi_outdoors's Avatar
more rigid
upside down forks are inherently a more rigid system, compare them to regular forks, side by side, and you should get a sense of why
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #5 of 6 Old 05-04-2014, 11:20 PM
Bugzy's Avatar
The advantage of the upside down design is that the larger diameter outer tubes are held by the triple clamps, while the fork inner tubes are attached to the wheel axle. This layout makes for greatly increased front fork rigidity by allowing the use of longer inner fork tubes which increase overlap (from a Yamaha design webpage).
I wonder if inverted forks leak more?
Bugzy is offline
post #6 of 6 Old 05-04-2014, 11:57 PM
Another advantage of inverted forks is the lighter unstrung weight. A drawback is the lower, inner tube more exposed to damage.
