Question about dropping the front - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-03-2014, 02:54 PM Thread Starter
MontanaGuy's Avatar
Hi,
Decided to try out a set of lowering links on my DL K5 1000. I've read that you can lower the front forks to 15 mm and my question is this. Is it 15 mm. from the top of the forks to the triple tree, or from the top of the forks to the locking nut on the triple tree? Thank you for all of your help out there folks!
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #2 of 7 Old 05-03-2014, 04:43 PM
If you figure that the 'shoulder' of the fork sits flush with the top of the triple tree/yoke, then drop it through 15mm, so that a further 15mm of th fork is exposed above the triple tree. Make sure the bike's weight is supported throughtout this process, I'm sure you know that already.
dogdaze is offline
post #3 of 7 Old 05-03-2014, 05:10 PM
10-15mm from the top of the chromed steel tube, not including the aluminum top nut, to the triple clamp where it contacts the tube is good with a stock rear height. It can be lowered as much as 21mm.
post #4 of 7 Old 05-03-2014, 11:28 PM
BluesCruiser's Avatar
Is there an advantage to doing this other than lowering the seat slightly? Do you also lower the back the same amount?
2009 Wee-ABS
"Anything worth doing is worth doing slowly" (Mae West)
BluesCruiser is offline
post #5 of 7 Old 05-04-2014, 12:24 AM
Vees and Wees have front end aerodynamic lift at high speeds. Lowering the front or raising the rear limits that and quickens steering. I was so much happier with the front lowered 10-15mm on my Wee.
post #6 of 7 Old 05-04-2014, 11:42 AM Thread Starter
MontanaGuy's Avatar
Thanks GW. The front is already 15 mm. down as per your description. Once the 7/8 in. lowering links are installed (still waiting for the parts), then I still have another 6 mm. "fudge" room. I was reluctant to try the lowering links because I like the way the bike handles as it is now. But after I dropped it when the pavement slanted away from me, it got me to thinking this is still somewhat of a problem. Will adjust the front to 21 mm. and see how it rides after the links are installed. Still not convinced this is the right way to go, but if it handles well and gives me more control at a stop, then it will be a winner.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
post #7 of 7 Old 05-04-2014, 08:55 PM
I dropped mine 13mm from the top of the tubes today; a very easy adjustment to do with a jack under the front of the engine case. Took it for about 40 miles in a strong wind and it SEEMED to make a difference. Hard to say, but it certainly isn't worse.
2009 Wee-ABS
