Does the front axle have a spacer?? (see photo) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 04-29-2014, 11:19 PM Thread Starter
I recently removed the front wheel on my K9 Wee & took it to my local dealer for a new tire. After I re-installed it, I noticed that the right side appeared to be missing a spacer (see attached photo). Thinking that it had fallen out as I was removing the wheel, I looked everywhere on my shop floor for the "missing" spacer. After I couldn't locate it, I looked up a schematic of the front wheel on the internet, and I was shocked to see that the axle doesn't have a spacer.
Excuse my mechanical ignorance, but without a spacer in this area, what keeps the wheel perfectly in place? The only thing that I can see keeping it in place is the rotor sandwiched between the calipers.
Thanks in advance for the info.
j-man is offline
post #2 of 7 Old 04-29-2014, 11:30 PM
kiwi_outdoors's Avatar
on my ABS bike
I have the speedo gear on one side, and my ABS sensor on the other side
for my non-ABS bike, the manual shows an open space on the side opposite the speedo drive, there is a shoulder on the axle (your missing spacer area) that squeezes all the bits and pieces over to the fork tube with the speedo gear - that is how the entire assembly is located.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #3 of 7 Old 04-29-2014, 11:32 PM
tmcgee's Avatar
I've had the front wheel off 3 DL650's many times, I'm pretty sure there is a spacer.
tmcgee is offline
post #4 of 7 Old 04-29-2014, 11:42 PM
I did the same as the OP... Freaked out about 'losing' a spacer and installed the wheel. it looks like the axle has a shoulder on it- no need for a spacer... Rides fine... Glad to know I didn't 'lose' the spacer but only momentarily most my mind:-)
2007 DL650(purchased 05/17/13 with 2,785 miles) now 10,200 miles and counting (06/24/2014) Farkles: Givi E36. Bestem 929 top box, HT center stand. Dan Vesel Highway pegs, grip puppies,
Wyhunter1988 is offline
post #5 of 7 Old 04-30-2014, 01:09 AM
There is no spacer. The axle shoulder butts up against the bearing and the fork leg is held in the proper position by the pinch bolt on the fork leg.
post #6 of 7 Old 04-30-2014, 09:19 AM
Downs's Avatar
NOt sure on the ABS model but on the non-ABS model there is no spacer technically.
The speedo sensor and the shoulder on the axle work as spacers.
Downs is offline
post #7 of 7 Old 04-30-2014, 10:10 AM
See the parts fiches:
ABS - 2009 Suzuki V-Strom (DL650A) FRONT WHEEL (DL650AK7/AK8/AK9) | MRCycles
Non ABS - 2009 Suzuki V-Strom (DL650A) FRONT WHEEL (DL650K7/K8/K9) | MRCycles
The axle goes through a seal directly into the bearing, no spacer.
