Cheap Air Filter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 40 Old 04-16-2014, 12:44 PM Thread Starter
Cheap Air Filter
www.dropbox.com/s/38kmzplszlkasdp/filters2.png
I suck at this img doesn't work for me
I am cheap and I resent what I consider gouging. The fact Suzi wants $45 for an air filter is ridiculous.
This is a chemically resistant plastic plate cut to fit the airbox with a Purolator 3916 airfilter. It is a Chevy filter and has almost 2 times more pleats and surface area than the stock Suzi. My bike runs great. I have seen 3916 for as little as $4 but everyday at Walmart for $6
I silicone glued the filter to the plate and I have great confidence it will last many years but for $6 I will be changing it regularly.
When time to change I will will cut through the adhesive and glue on a replacement.
If anyone is interested for the plate I want $20 plus postage just PM me.
Greywolf if it turns out to be a thing I will sign up as a Vendor
richw is offline
post #2 of 40 Old 04-16-2014, 01:06 PM
Looking at your fabricated plate, I am concerned with the seal between the edge and the gasket. The oem filter has a ridge that is formed to fit the gasket.
JustSaying is offline
post #3 of 40 Old 04-16-2014, 06:58 PM Thread Starter
The overall thickness is the same their ridges vs the thickness of the plate
The overall thickness actually appears heavier and the airbox lid snugged down well on the gasket
richw is offline
post #4 of 40 Old 04-16-2014, 07:16 PM
Tall Man's Avatar
False economy. And I've no love for part pricing trends, either.
The factory air filter does not require frequent replacement and can be refreshed with a careful blast of air. It is sold for ~$31.00 online at SHS. Or, spend $50.00, once, for a K&N.
Tall Man is offline
post #5 of 40 Old 04-16-2014, 07:30 PM
Richw! Kudos to your true diy ethitic.I used to use alternate air filters and silicone to fill gaps on my Guzzi,s never had any troubles. I,ve found that the stock Suzuki air filter can be cleaned by raping the ridgid edges on a hard surface several times with a piece of white paper underneith to see what comes out, continue till nothing apears,contrary to the service manual of using compressered air.Am using mine to 15,000 miles,seams better than McGyvering them for a more than a few dollars, considering the damage that could be done if the job is botched.
71 BSA Victor 500, 78 Yamaha XS750, 83 Yamaha Seca 550,
01 Triumph TT600, 98 MG Ev1100, 02 MG Lemans V11,14 kawi klx250s, all sold except 2012 Suzuki Dl1000
v2rider is offline
post #6 of 40 Old 04-16-2014, 07:40 PM
teevee's Avatar
i think it's fairly obvious that all vehicle manufacturers make the lion's share of their profits on parts, not the sale of the vehicle. try this on for size: try pricing every part on a DL and tell me if the total is less than $35,000.
frame fiche parts: ~$3600
crankcase: ~$1700
cowling: ~$1200
front wheel: ~$500
rear wheel: ~$1000
cylinder heads: ~$1500
throttle body: ~$1200
$10,700, and you have about 1/2 the bike, if that.
'08 DR650, '07 DL1000
teevee is offline
post #7 of 40 Old 04-16-2014, 07:44 PM Thread Starter
Well I shook and vacuumed my stocker but it was still gray afterwards
I assume the gray is fine dirt remaining and am unsure of what is the life and what is the method of failure or the effect on air flow from age/mileage.
Meanwhile the brandy new white as snow with MORE surface area 3916 is usually in service for the year and then another brandy new white as snow one will be installed in its place for $6
Doesn't sound false to me, and maybe my 60's mentality of sticking it to the man when they are trying to stick it to you.
If people did not seek out the cheapest gas station then ALL gas would be a dollar more at least.
cheers
richw is offline
post #8 of 40 Old 04-16-2014, 09:32 PM
Tightass's Avatar
K&N, reusable , last air filter you'll ever buy if you maintain it. Not plugging the brand. Just the reusable idea. If there are others go for it.
Tightass is offline
post #9 of 40 Old 04-16-2014, 09:44 PM Thread Starter
I would be K&n if never did dirt even dirt roads
richw is offline
post #10 of 40 Old 04-16-2014, 10:29 PM
I tried the auto air filter. The pleats were so tall that they mashed together and restricted the air flow.
