Cycle Gear Trackside steel bars, anyone tried them? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-15-2014, 11:39 AM Thread Starter
Hammerdown77's Avatar
Looking to start down the path of getting a more comfortable bar configuration. Considered risers, or new bars, or both. I don't really know if I need the bars to come up and back, or just up, or how much/little pullback I need. I have stock bars on now (2007 DL1000)
I have factory Suzuki heated grips on the bike, and swapping bars may compromise the left grip, depending on how much glue the shop used when attaching it. Also, I don't want to have to get longer cables or brake lines right now.
There's a Cycle Gear in town, and I saw these bars on their website. They seem to be similar to the MSR bars I've seen people recommend here. Has anyone used these? What is the "CR Hi Bend" like and how does it compare to the MSR ATV Hi I often see recommended?
I might be better of trying risers first, but since these are available at a shop close to me, and are inexpensive, I thought they might be another good option to try.
TRACKSIDE - Steel Handlebar - Other Add-ons - Add-ons - Accessories - Cycle Gear
Livin' the dream
Hammerdown77 is offline
post #2 of 10 Old 04-15-2014, 12:14 PM
rubenz's Avatar
I have these bars and like them. They are about 3/4 an inch taller than stock I think and have a much less angle so the wrists are not under as much pressure. It's a standard dirt bike style. I used to run the same bend on my old dr350 and drz400 so it's very familiar feel to me on the strom.
2006 DL650
Growing farkle list: Aux LED's on SW Motech Light Bar, Bark Busters, OEM Touring Screen, Bestem LED Top Case, Charging Port, DL1000 Seat, Madstad Bracket w/MP Cycles Windscreen, Pat Walsh Design Radar Shelf, Neslon Rigg CL-855 Luggage, Givi Engine Guards, Sargent seat.
Iron Butt Association Member - Qualified with 1,118 mile Saddlesore
rubenz is offline
post #3 of 10 Old 04-15-2014, 02:28 PM Thread Starter
That's good info, thanks. I've been looking for some dimensions online, and can't really find anything, so I didn't know how tall they were compared to stock. I figured they had less pullback than the OEM bars, though.
If they're only 3/4" taller than stock, I'll probably want to try something else. Looking for about 2". We have another more dirt bike oriented shop here close by, I may check them out to see what they have.
Livin' the dream
post #4 of 10 Old 04-15-2014, 02:42 PM
rubenz's Avatar
I was just estimating on the height. I had the stock bars on for about 2.5 minutes. They killed my wrists. So I may be off on its height. Yes they don't pull back as far. Any CR HI bend bar will have the same dimensions so maybe something will come up online.
2006 DL650
rubenz is offline
post #5 of 10 Old 04-15-2014, 02:43 PM
rubenz's Avatar
Here we go!
Handlebar Configuration data (Width, Height, & Pull Back)
2006 DL650
rubenz is offline
post #6 of 10 Old 04-18-2014, 04:50 PM Thread Starter
Local shop had the Fly Racing 7/8" steel bars in the standard ATV bend for $18. Checked out the dimensions and looks like they are 6" high, with minimal pullback (about 2.75"). Not sure if they would work.
Fly Racing 1010 Carbon Steel 7/8" Standard Handlebars - Motorcycle Superstore
Haven't made it over to Cycle Gear, will try tomorrow.
Livin' the dream
post #7 of 10 Old 04-21-2014, 12:50 PM Thread Starter
Finally made it over to CG, and they had the Fly Racing bars, but not the Trackside. Got the Fly Racing ATV. Upon mocking them up on the bike (didn't remove anything off of the old bars), they are noticeably less wide than the factory bars. Quick check of Fly's specs show about 28" wide, compared to the stock bars 30". This concerns me, and I need to take some additional measurements to see if there is room for all of the controls. Don't really want to start taking stuff off the old bars if it's going to be a no-go from the start (I have heated grips, and whatever hassle that might entail during the removal process).
Forgot to take pics, maybe I can get some later today.
Livin' the dream
post #8 of 10 Old 04-21-2014, 01:03 PM
redbarber's Avatar
Actually, that slight difference in width may be a blessing for you. Cables, hoses, lines, wires all have 1 inch less to get where they need to go, which should offset some of the additional height. When I moved my 1" risers from my 2005 to my 2009 ABS, I had to replace the brake line. Apparantly the extra slack available on the non-abs model was designed out of the abs version.
redbarber is offline
post #9 of 10 Old 04-21-2014, 01:14 PM Thread Starter
This is a good point.
Livin' the dream
post #10 of 10 Old 04-21-2014, 03:48 PM
rubenz's Avatar
I also wanted to add that I also have the trackside bark busters on my bike. Very very solid. HOWEVER, they do hit the fairing a bit before full lock which I do not care for but I live with it.
2006 DL650
rubenz is offline
