Rust in Tank - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-13-2014, 01:40 PM Thread Starter
Rust in Tank
I've run a couple tanks thru T-Strom with no noticeable problems. I know I'm running on borrowed time. Any ideas on how to remedy the rust? What is the worst that can happen??
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #2 of 13 Old 04-13-2014, 02:14 PM
There used to be this stuff you put in the tank and roll it around, it coats the inside....lots of antique car guys have used it with success...surely google knows....
slickster57 is offline
post #3 of 13 Old 04-13-2014, 02:21 PM
fortp's Avatar
Last year I saw the result of an old and very rusty VTT tank, that has been repaired by a kit in 2 or 3 steps, and it was very impressive. But I dont remember the name of the kit. Maybe this one:
POR-15 Fuel Tank Repair Kit Review | Rider Magazine
fortp is offline
post #4 of 13 Old 04-13-2014, 04:29 PM
cpd419's Avatar
Be prepared to do it about every year. I would look for another tank. Nothing but trouble.
2013 DL650
cpd419 is offline
post #5 of 13 Old 04-13-2014, 04:36 PM
Mastery's Avatar
Bingo. Rust is cancer. Very hard to stop by putting something over it, because it spreads under the coated surface.
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #6 of 13 Old 04-13-2014, 04:44 PM
The filter may start clogging. If it gets to where it won't rev as high as it did, it may be stopping up.
fearandcommonsense is offline
post #7 of 13 Old 04-13-2014, 05:06 PM
Find Oxalyc Acid in deck brightener found it will remove the rust
If you can get it out I used to use gravel with it too.
Cream or Por tank liner works OK
richw is offline
post #8 of 13 Old 04-13-2014, 06:17 PM
fortp's Avatar
What I saw, was not just something that coated rust. The rust was completely removed before.
fortp is offline
post #9 of 13 Old 04-13-2014, 06:52 PM
Nostromdumbass's Avatar
does the "rust" look anything like this?
https://www.stromtrooper.com/871205-post7.html
An original quote by Nostromdumbass;
Facebook: making humanity yearn for the times when people used to talk behind others backs.
Nostromdumbass is offline
post #10 of 13 Old 04-13-2014, 06:56 PM
LordSmoke's Avatar
My second-hand information tells me his is one of your best bets: ** Welcome to Kreem Products.com **
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
