Tried the Motion Pro Bead Breaker last week - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 27 Old 04-12-2014, 11:29 PM Thread Starter
Strider1520's Avatar
My front tire was getting cupped fairly badly and decided to swap the rear as well. It was a Kenda (the only size a dealer had when my Heidenau K60 belt delamintated on me on the way to Houston. Still had some miles left in them, but wanted to try the Shinko 705's. Ordered a MotionPro Bead Breaker with the tires.
I had the old hammer type wedge bead breaker and man, let me tell you, these worked like a charm.
Deflate the tire, remove the stem and insert the bead breaker.
Press together (didn't require much force) and PRESTO!!! Bead broken. Worked it around and made sure it was broken in 2-3 other places, flipped and did the same on the other side.
Also used the spoon on the other side of the bead breaker to help me along with my normal iron. Worth the money.....did what it was suppose to do.
Speaking of the Shinko's. I like them thus far. More road whine than other tires I have had on, but I really like the tire - and the price is sweet.
Strider1520 is offline
post #2 of 27 Old 04-13-2014, 12:21 AM
Eric Lorenz's Avatar
Cool. Before I gave up my GS750, I had worked up enough nerve to do an oil/filter change on it...and had previously done some other minor things (battery replacement/maintenance, lamps, etc.) I have not gotten to the place yet where I think I could do that. For me, right now, that's a "I'm gonna run it over to Racer Cafe and let THEM do that". Once we get back into a house, and I have a real garage, with a place to do work like this, I might consider it.
Eric Lorenz
Aurora, IL
2007 DL650A
Eric Lorenz is offline
post #3 of 27 Old 04-13-2014, 12:26 AM
bwringer's Avatar
I've used a very similar technique with three tire irons to break beads many times. Works very well, even on the most stubborn tires.
bwringer is offline
post #4 of 27 Old 04-13-2014, 07:31 AM
Supatramp's Avatar
I got a MPBB about 6 months ago and it's been accepted well into my tool kit.
It's broken all the beads, I've used it on, including the large Harley rims.
I pour some lube all the way around the rim and gently worked it 360 degrees.
Before you know it, pop.
I don't go at tire work like a bull in a China shop, and have gotten to where I'm not tearing up my rims and scratching them. I'll use rim protectors when required.
By the way, I've found Shinko's at Pinwallcycle in Ohio, the cheapest anywhere, with free shipping. They sent 'em FedEx, and were in NJ, in four days.
A front & back 705 for the Glee, $149.
Supatramp is offline
post #5 of 27 Old 04-13-2014, 08:23 AM
jgonzo's Avatar
Are you guys balancing then?? If yes, how you doing them?
Garage......
Oh Yea: '17 Aprilia Tuono Factory
'14 DL1000
'02 Daytona 955ce
'87 ZL1000
'85 &'86 ZL900's
jgonzo is offline
post #6 of 27 Old 04-13-2014, 08:44 AM
chicago's Avatar
I put on a set of tires using this tool plus a set on my neighbors XL 650. I was very impressed. It is so easy. This is the one.....you need this tool.
How to balance your wheels - Motorbike Parts & Accessories Reviews | MCN
chicago is offline
post #7 of 27 Old 04-13-2014, 09:43 AM
I picked one up at a great price but have not used it yet.. Good to know it works as advertised.
I HAVE used this little jewel with great success. Makes getting the last little bit over the edge a snap.. The leverage is so powerful it will cut the tire if your not careful. Not a deal breaker, just you have to be wary…like scratching your rims. I have used it on very stiff rear Sport touring tires and K60's… piece of cake..
This is the original and where I got mine in a group buy on ADV..From Yurp
Kaurit-Moto
American version for "cheaper" Looks to be the same…
Baja NO PINCH Tire Tool
https://www.youtube.com/watch?v=DsP6PglNkFE Tool used at about 4:50
Mitch
Hollyweird, Fla.
mitch96 is offline
post #8 of 27 Old 04-13-2014, 09:56 AM
@Strider1520 - Thanks for trying one of these and doing the write-up w/ pics.
I was leery of buying one since I still have a sour taste in my mouth from buying their Bead Popper.
Their Bead Breaker, on the other hand, appears to do what it was designed to do, so I guess it's time to buy the big one for the shop and the small one for the tool roll.
"Making bad choices since 1948...."[LEFT][SIGPIC][/SIGPIC][/LEFT]
Leroy is offline
post #9 of 27 Old 04-13-2014, 10:19 AM
Kauritmoto tool
I thought the kauritmoto tool was only for tube tires. Have you used it to change tubeless tires? Did you need an axle adaptor to use it for the vstrom?
Kaurit-Moto
Certified JB Welder
2017 Africa Twin
2012 DL650 EXP (traded)
2012 WR250R
dogen is offline
post #10 of 27 Old 04-13-2014, 11:03 AM
Do you balance the wheels with new tires?
Ride safe!
V Strom DL650 - 2013 Riding
V Strom DL1000 - 2007 Sold
Honda Shadow 750 - 2000 Sold
Pauloxxi is offline
