Comfort difference in seat 1000 vs 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-10-2014, 03:32 PM Thread Starter
Ok all, did the search and read...
Wanted to know from someone who has switched from the 1000 seat to the lower OEM 650 seat, how does it compare in comfort? I don't mind the 1000 seat, but it's a tad high... I know the 650 seat has less padding, but does it make it uncomfortable (or noticeably more uncomfortable than the 1000 seat?)
Thanks
2009 Vee
Dash8 is offline
post #2 of 8 Old 04-10-2014, 03:56 PM
RichDesmond's Avatar
It was less about the padding, per se, than it was the shape. I hated the 650 seat, the 1000 was at least tolerable. The Corbin is great!
That said, everybody's butt is different, there are a few people who actually like the 650 seat.
Rich Desmond
RichDesmond is offline
post #3 of 8 Old 04-10-2014, 03:56 PM
My bike came with both. I rode on both, but switched to the 650 seat because it is lower. 28,000 miles and loving it
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #4 of 8 Old 04-10-2014, 04:51 PM
rubenz's Avatar
I switched from the 650 seat up to a 1000 seat and the 1000 seat is a bit wider and obviously taller. My butt felt about the same after say a 2 hour ride ( getting uncomfortable) but my knees were much happier due to the extra room. So be careful switching to the 650 seat because it will put more pressure on the knees.
2006 DL650
Growing farkle list: Aux LED's on SW Motech Light Bar, Bark Busters, OEM Touring Screen, Bestem LED Top Case, Charging Port, DL1000 Seat, Madstad Bracket w/MP Cycles Windscreen, Pat Walsh Design Radar Shelf, Neslon Rigg CL-855 Luggage, Givi Engine Guards, Sargent seat.
Iron Butt Association Member - Qualified with 1,118 mile Saddlesore
rubenz is offline
post #5 of 8 Old 04-10-2014, 06:36 PM
Transferability of seats between the DL1000 and the DL650
I have 2012 DL650. While I find the stock seat comfortable enough as far as it goes, I wish it were a little taller. I'm 5'11", have a 32" inseam, but have had a knee replacement and lost some range of motion in my right knee. Does anyone know how much taller the DL1000 seat would be and is it transferable?
BobRench is offline
post #6 of 8 Old 04-10-2014, 06:50 PM
The DL 1000 seat will interchange only with the '04-'11 DL 650's. The 2012 and newer DL 650 seat is completely different.
realshelby is offline
post #7 of 8 Old 04-11-2014, 12:29 PM
I have both for my V, I prefer the 1000 seat for comfort but like the lower seat ht on the 650 seat. Since switching to the 1000 seat again I have not used the 650 seat
Buffalo rider is offline
post #8 of 8 Old 04-12-2014, 01:14 PM
MontanaGuy's Avatar
I've switched to a 650 seat on my Vee. Like it better for height (also removed all but the front rubber bumpers). Comfort wise I am very comfy with it. This might be a factor of my weight also. Only weigh in at 143 lbs. and 5'7". If you are larger, it may not be as comfortable for you.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is online now
